Thread: Key stuck in ignition.
Results 1 to 12 of 12
  1. #1 Key stuck in ignition.
    Feb 2010
    Oak Harbor, WA
    So yesterday I was tooling around town doing some errands and when I stopped at the post office, I couldnt pull my key out of the ignition. Right now it needs one more click to let me pull out the key. Also all I have to do it press the brake and the trans will go into gear. Is there anything that I can do to try and get the key out before I have to go and put down more money on my car. I just spent almost 600 on new brakes because my fronts wre really warped and my rears were rusted beyond repair.
  2. #2 Re: Key stuck in ignition.
    Nov 2009
    Grand haven
    Seems like your shift cable linkage is out of adjustment. I would start there.
  3. #3 Re: Key stuck in ignition.
    Charles City, IA
    Your park lock solenoid is broke take it out and your key will never get stuck agian.
    SMGPFC Two Nipple General
  4. #4 Re: Key stuck in ignition.
    Feb 2010
    Oak Harbor, WA
    Where is that at?
  5. #5 Re: Key stuck in ignition.
    Canada
    what year is your car? new ones if you shut off your car before putting it into park will stop the key from being released. start your car and put it in reverse then back to park then shut off your car.
  6. #6 Re: Key stuck in ignition.
    Feb 2010
    Oak Harbor, WA
    Quote Originally Posted by checkinpox View Post
    The car is a 98 GT.
  7. #7 Re: Key stuck in ignition.
    Charles City, IA
  8. #8 Re: Key stuck in ignition.
    Feb 2010
    Oak Harbor, WA
    So today I finally took care of the Key being stuck. I opened up the cowl under the steering wheel, and loosened the connector on the bottom of the park lock solenoid and the key came right out. Thanks for the direction and this saved me a crap load of money because I didnt have to go to a shop and have them troubleshoot it and me end up paying over a $100 for something simple.
  9. #9 Re: Key stuck in ignition.
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Quote Originally Posted by at2smithjason View Post
    it is possible for this problem to correlate with other symptoms and is caused by a bad ignition switch. if you begin to have problems with auto lights and climate controls, swap out the switch.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  10. #10 Re: 2002 Grand Prix GT Key Stuck in Ignition.
    Columbia, SC
    Remove the center console and check the harness attached to the shifter. There's a switch that senses that the shifter is in Park. I found a very fine wire broken right at the connector. All I had to do was solder the wire to the harness connector and life was good again!
  11. #11 Re: Key stuck in ignition.
    Canada
    you can buy that connector from gm for about 50 bucks and it replace all the wire going to the switch. very common problem according to the dealer.
  12. #12 Re: Key stuck in ignition.
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    just take the lock cylinder out, it's not that important, ^^and allot better than wasting $50...IMO
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. key stuck in ignition....
    By fst in forum General Tech Discussion
    Last Post: 01-21-2010, 06:06 PM
  3. key stuck in ignition?
    By jaketrey32 in forum General Tech Discussion
    Last Post: 05-15-2009, 05:28 PM
  4. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
  5. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
