and Trannyman popped a piston on his first run with a set of Brisk silver racing plugs installed:th_shakinghead1:
:th_biggrin2:
wow....thats odd...almost makes me not want to get them lol
Good point. The idea behind Pulstar plugs is sound. In other words, plasma ignition is not really anything new. What troubles me with the Pulstar plugs is the voltage claims they make. I just dont see how those numbers are possible. In a modern electrical ignition system, the math doesnt work.
I can tell you all for sure...don't ever buy Bosch Platium Plugs. I put them in my wife Bonniville and it would not run right. I finally took them out and put some AC's in it and it was fine. Then I had a 98 Stratus that would not idle right when I bought it and I checked..sure enough...Bosch Platiums so I switched them out with Autolights and that fixed it.
Rob
Im pretty convinced that its not so much BOSH as it is the configuration of the plug. Its a surface discharge plug. It should work better with lower voltage ignition systems, but making it a platinum plug changes that slightly. It doesnt take as much voltage for a surface gap plug, but I believe when it does spark its not as strong as a conventional plug.
I agree, I run the bosh in my bravada with no problems, but in the gp so far has been autolite (may try some ngk next, but will never run another ac plug or champion have had too many problems from both)
You all have problems with AC's? I haven't but have to say...I don't think I have had a problem with NGK's. I don't even know what's in the GP. I need to look at them. To many other problems right now with it. It runs good so I figure I'll check them when have a little time.
Rob
is everyone refering to ac's meaning ac delco?? just checking
I am ( realize they are no longer gm made products either)
ok i was just checking
That's what I was talking about.
