Thread: Door locks unlock & interior Lights by itself
Results 1 to 2 of 2
  1. #1 Door locks unlock & interior Lights by itself
    Feb 2010
    Boulder
    Hello, I have a 1999 Grand Prix GT and it has started to unlock itself randomly while I am driving and after car is shut off. Both doors will unlock and the interior lights come on and dim every few minutes when key out of ignition. I have removed fuse from locks saving actuators though still hear relay engaging every 30 seconds or so. Further I have found hitting lock once on key FOB after key out of ignition stops lights from cycling on and off. Please advise after review. Thank you.
  2. #2 Re: Door locks unlock & interior Lights by itself
    Feb 2010
    Boulder
    Found problem. Upon inspecting wiring near door lock assembly on drivers door. Found wire being pinched by insulation and shorted. Repaired wire. Ding Dong the witch is dead. Problem solved. Hope this helps
  1. Key won't unlock door
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 01-05-2010, 05:01 PM
  2. Disabling automatic door locks
    By BlackHawk99 in forum Audio, Security & Visual Electronics
    Last Post: 09-15-2009, 08:02 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
  4. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
  5. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
