Thread: Need help with with rear strut mount??
Results 1 to 7 of 7
  1. #1 Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
    I was looking for a car for a friend i found one and this was the only problem "The problem is the strut on the back right rusted through the trunk." is there a fix for this she is not going to get the car but i went outside to see mine and it has a little bit of rust is there not much... anything i can do before it rusted through???(Michigan weather) Thanks
    Does anybody here has this happen to there car??
  2. #2 Re: Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
  3. #3 Re: Need help with with rear strut mount??
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    its on most gps. idk what to do to fix it tho
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  4. #4 Re: Need help with with rear strut mount??
    GTX Level Member Deimos's Avatar
    iowa
    POR15 does wonders. If you are keeping your car use that paint.
  5. #5 Re: Need help with with rear strut mount??
    Nov 2009
    Grand haven
    Get rid of it while you can and buy one from down south.
  6. #6 Re: Need help with with rear strut mount??
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sand it down or wire wheel it, paint it or por15, then undercoat it i had many of these cars the rubber under coating helps a bunch cus when the strut towers get wet the water runs rite off, i do it to cars with no rust to prevent rust and yrs later still no rust
  7. #7 Re: Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
    Ok so i found the pro15 am going to order it online thanks for the info any other ideas let me know thanks
  1. Strut Mount Caps?
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2010, 11:50 PM
  2. missing spacer on rear strut mount '06 GXP
    By tta1401 in forum General Tech Discussion
    Last Post: 07-25-2009, 05:19 PM
  3. Strut Bolts Stuck on Rear Knuckle
    By VerticalMK in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2009, 11:34 PM
  4. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  5. 98 NAPA Front Strut Tower Mount
    By Lion29GTP in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2009, 02:10 AM
