Thread: Key stuck in ignition
Results 1 to 6 of 6
StreetChariot Key stuck in ignition 04-04-2008, 07:52 PM
archemedes Re: Key stuck in ignition 04-05-2008, 10:48 AM
StreetChariot Re: Key stuck in ignition 04-07-2008, 04:48 PM
archemedes Re: Key stuck in ignition 04-08-2008, 06:15 AM
StreetChariot Re: Key stuck in ignition 04-08-2008, 06:19 PM
stlmo_gtp Re: Key stuck in ignition 04-08-2008, 06:36 PM
  1. #1 Key stuck in ignition
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    OK. I've read everyone elses' posts on the "key stuck in ignition" issue, and all I've seen sofar is a quick fix with a zip tie. Has anyone figured out how to fix this issue?
    On my GP, not only does the key get stuck sometimes (Not able to turn it to OFF or ACC), but I am also able to remove it when driving by pulling it straight out of the tumbler. If I leave it that way for 3 or more seconds, the security light comes on, so I know the PK3 system is working.
    It is a 2000 GP SE if that matters.
    I am assuming whoever owned the car before me knew of the zip tie option, though I haven't checked to see if it is in place, since I am able to remove the key at any time.
    If I put the car in PARK, turn it one click back from ON, (to stop the engine) and turn it back to ON without starting it, and move the shifter from park to 1st gear, then slam it back to PARK, the key will sometimes come out.
    It is a pain!
    Should I suspect the Shifter Cable? I'm guessing it is not the solenoid for the key cylinder, since I can pull the key out while in ON. What else could it possibly be?
    Thanks,
    StreetChariot
  2. #2 Re: Key stuck in ignition
    Saraland Alabama
    if you can remove the key with the switch on your switch is bad
  3. #3 Re: Key stuck in ignition
    Cowtown, OH
    What do I need to replace? The whole ignition, or just the black box under it?
    Thanks,
    StreetChariot
  4. #4 Re: Key stuck in ignition
    Saraland Alabama
    the tumbler switch is bad at least
  5. #5 Re: Key stuck in ignition
    Cowtown, OH
    I'll take a look around tomorrow at the yard to see if I can find one. Is it universal among GP's?
  6. #6 Re: Key stuck in ignition
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    if you get a whole new ignition i do think that it needs to be keyed so that your key will work for it
  1. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  2. Key stuck and Dead Car
    By joe_cool in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2010, 04:13 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
