Thread: what cause the lights ?
Results 1 to 16 of 16
  1. #1 what cause the lights ?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    ok until now i thought that the tie rod end was the problem but i am still not sure, here is what is going on my ABS light and Traction Control Light come on at the same time,and there is a shake in the wheel. and here is the check list i have already gone threw:
    1.checked my brake fluid, bcause i heard that can cause the ABS light to come on.
    2.Checked the tie-rods by jacking up the car, and shaking the tire but there is no play
    Does anyone eles hve any idea's of what could be going on ?
  2. #2 Re: what cause the lights ?
    Hoffman/Schaumburg, IL
    Sounds like a Wheel bearing to me
  3. #3 Re: what cause the lights ?
    Fayetteville, AR
    You need a new wheel hub, the bearings have gone bad in it. I had the EXACT problem happen to me, the ABS and low trac light both stayed on and the car would shake really bad at speeds of 65 mph and up. Get a new wheel hub on there and clear the DTC codes with a ODB II and you're good to go! Best of luck to u!
  4. #4 Re: what cause the lights ?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    the obdII scanners wont clear out the abs codes, but once you make the problem go away, the light wont come on... the code will just be stored as past history
  5. #5 Re: what cause the lights ?
    St. Louis
    yea i was kinda hopping that, that wasn't the problem but on well seeing as i got the same answer from everybody i think it is pretty safe to say that it is the problem
  6. #6 Re: what cause the lights ?
    SW Chicago Suburbs
    yeah... it's a pretty sure bet.
    the ABS light coming on 'cuz the sensor is messed up, and the traction control cant function without the ABS, so the trac off light goes on, too... so it's a dash light partaaay!!
    heh
  7. #7 Re: what cause the lights ?
    Oklahoma
    Has anyone suggested that it is possibly the wheel bearing?
  8. #8 Re: what cause the lights ?
    SW Chicago Suburbs
    you havent been very observant of the last couple posts, bud.. go back to sleep
  9. #9 Re: what cause the lights ?
    Oklahoma
    Why I oughtta........
  10. #10 Re: what cause the lights ?
    TDCRacing
    Guest
    God,pay attention Scotty!
    Guess it would be kinda hard to ban you huh?
  11. #11 Re: what cause the lights ?
    Oklahoma
    Quote Originally Posted by TDCRacing View Post
    Hard, but not impossible. Guess I could ban myself, LOL.
  12. #12 Re: what cause the lights ?
    PA
    Is that electronically possible for you to push the ban button on yourself?
    2001 GSE
  13. #13 Re: what cause the lights ?
    Oklahoma
    I believe so, though Im not about to experiment. At least the option appears to be there for me to do it.
  14. #14 Re: what cause the lights ?
    TDCRacing
    Guest
    I say go ahead and try it...WE have nothing to lose...It's not like your any help here or anything lol
    let us know how the wheel bearing hub fix comes out when your done
  15. #15 Re: what cause the lights ?
    Oklahoma
    Note to self: Put TDCRacing at top of sacrificial member list.
  16. #16 Re: what cause the lights ?
    TDCRacing
    Guest
  1. Just parking lights?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 09-01-2008, 01:24 PM
  2. Custom Fog Lights Only
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 05:29 AM
  3. Dash lights out
    By archemedes in forum General Tech Discussion
    Last Post: 01-24-2008, 01:13 PM
  4. Looking for new headlights and fog lights
    By robahr24 in forum Visual/Body Modifications
    Last Post: 01-20-2008, 12:44 PM
