Thread: My heat only BLOWs on WINDshield?
Results 1 to 17 of 17
  1. #1 My heat only BLOWs on WINDshield?
    chicago
    help me.. my heat only blows on the windshield.. is this the blower motor resistor??? or do I need something else aswell..... Thanks guys before hand..
  2. #2 Re: My heat only BLOWs on WINDshield?
    Wooster, Ohio
    probably your vacuum line to run your climate control, which runs across the firewall to the engine. If it becomes unhooked then it won't select anymore
  3. #3 Re: My heat only BLOWs on WINDshield?
    chicago
    whoah thanks for the quick reply yo.. so by any chance would you have some suggestive remedies?? can i fix this myself with my limited knowledge... or is this a biggie that only a pro can take on??
  4. #4 Re: My heat only BLOWs on WINDshield?
    chicago
    well can I HOOK this back up?
  5. #5 Re: My heat only BLOWs on WINDshield?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    if that is indeed the problem, yes. it is as simple as that.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: My heat only BLOWs on WINDshield?
    Guam
    The default setting is defrost on the windshield. It is either a vacuum issue, or if you have electronic climate controls, the mode door actuator is bad.
    To fix, you need a vacuum gauge and strat checking vacuum under the hood, the line running into the car and inside the car. Next check all the actuators, temp, mode and recirc.
    If you have electronic climate controls, you need to replace the actuator, which is found in the dash board. Search the site for blend door, ot temp door, and a write up will come up.
    I wish it were the resistor, but it is not, that is for the blower fan speeds only.
  7. #7 Re: My heat only BLOWs on WINDshield?
    chicago
    thanks guys.. so i guess imma start with checking to see if the vacuum thing is unhooked...
    Anyone MIND letting me know or where I can find a write up on how to get to me vacuum line?/?/?
    also i just replaced my water heater.. could I had accidentally unhooked it then??? if so is it near the water pump
    thanks bros
  8. #8 Re: My heat only BLOWs on WINDshield?
    Guam
    The main vacuum line is behind the intake manifold, on top of the engine. It is also near where the large rubber brake booster hose comes out of, and goes to the master brake cylinder. It comes off of it, and then runs along the firewall until it gets to the passenger side. Then it bends and goes down near the battery. It is a hard black plastic line. If you start looking near the battery and work backwards, that might be easier for you. Or look along the fire wall for it and trace it both ways, to the battery and then to the engine. I do not know of a wrirte up to lead you to.
    This line goes into the car, through the passenger side. If you remove the glove box, you will see it inside the car then.
  9. #9 Re: My heat only BLOWs on WINDshield?
    Oct 2008
    Calgary, Alberta
    If it has been broken inside the wiring harness you can route a new line by the automatic shifter passthrough like i did, bypassing the vacume reserve.
  10. #10 Re: My heat only BLOWs on WINDshield?
    Topeka, KS
    There is a vac line down by the passengers feet near the console its purple i believe. See if its unhooked from a nipple. IF thats all cool its a blend door actuator and not fun to replace. I've done the passengers side on my car.
    I can get you instructions if needed.
  11. #11 Re: My heat only BLOWs on WINDshield?
    Wausau, WI
    I have kind of similar issues...the car heats as normal, and the fans work normally. I have the digital DCC on mine and my issue is that it will not blow warm air to the feet on either side. It will however switch from the defrost to the vents. I have no other issues but it will not switch down to the floor vents on either side...ideas? I would normally say blend door actuator, but if this is the case both of them would need replacement? And if this is true, wouldnt it not move at all? Any ideas anyone?
  12. #12 Re: My heat only BLOWs on WINDshield?
    chicago
    u guys have been huge help.. I will try to see what I can get done... I will report back... AND THANKS FOR ALL THE COMMENTS AND HELP... this GP community is the BOMB!!!!
  13. #13 Re: My heat only BLOWs on WINDshield?
    Iowa
    mine did the same thing a couple of months ago. Mine was that vaccum line like pitman said earlier. It has a coupler in it between the pass. shock tower and the firewall. Mine was just pulled apart.
  14. #14 Re: My heat only BLOWs on WINDshield?
    Wausau, WI
    Quote Originally Posted by IROC View Post
    yours did the same thing as mine or the same thing as the OP?
  15. #15 Re: My heat only BLOWs on WINDshield?
    SE Level Member Talsition's Avatar
    Stevens Point, WI
    Quote Originally Posted by Liquifire View Post
    I have the same problem, and it sucks when I have to drive it in the cold. Feet freeze and seems there is nothing I can do. I even replaced my DDC and that didn't help. For some reason I always thought the carpet got unhooks or something.
    98 Grand Prix GTP - Custom FWI, 104 autolites, 180* t-stat, TDR Fbody Break Kit
    95 Eagle Talon ESI - 2Gb Conversion, lots of mods still slow.
  16. #16 Re: My heat only BLOWs on WINDshield?
    Iowa
    same thing as yours
  17. #17 Re: My heat only BLOWs on WINDshield?
    Wausau, WI
    Quote Originally Posted by Talsition View Post
    welll...,either a vacuum line came unhooked or broke, or you have two blend doors that are bad...from what I have gathered anyway.
  1. Intake blows to pieces..fire erupts
    By GT Gurl in forum General Tech Discussion
    Last Post: 10-06-2010, 08:50 AM
  2. My intake sucks, my exhaust blows, and my car whines!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 09:13 AM
  3. ac blows a fuse
    By brown54b in forum General Tech Discussion
    Last Post: 06-28-2009, 08:38 PM
  4. 3.8 series II sc blows smoke with rev
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 01:09 PM
  5. Interior Light Fuse Blows....
    By hester21289 in forum General Tech Discussion
    Last Post: 03-12-2008, 08:02 PM
