the car heats as normal, and the fans work normally. I have the digital DCC on mine and my issue is that it will not blow warm air to the feet on either side. It will however switch from the defrost to the vents. I have no other issues but it will not switch down to the floor vents on either side...ideas? I would normally say blend door actuator, but if this is the case both of them would need replacement? And if this is true, wouldnt it not move at all? Any ideas anyone?
