Thread: Heat
Results 1 to 6 of 6
mongoclark Heat 02-05-2010, 06:43 AM
pacothetaco Re: Heat 02-05-2010, 09:30 AM
mongoclark Re: Heat 02-05-2010, 10:07 AM
bronzemist02 Re: Heat 02-05-2010, 11:06 AM
TheOtherNick Re: Heat 02-05-2010, 01:07 PM
pacothetaco Re: Heat 02-05-2010, 09:13 PM
  1. #1 Heat
    Michigan
    I have a 1997 Pontiac Grand Prix 3800 Supercharger. The problem is the heating system. Seems it blows really low even when the fan is turned up to 4 and when turned up to 5 the fan shuts off. There also is not alot of heat seems to be coming out when stopped at a light it blows cold and when you take off it starts to blow some heat. I changed the thermostat and replenished the coolant then had the system flushed out at the garage where they hook a machine to it. Seems it work somewhat a little bit but back to cold air. Any ideas?
  2. #2 Re: Heat
    Dec 2008
    philly
    check the blower motor high fuse in the glove compartment.
  3. #3 Re: Heat
    Michigan
    Just asking but what number fuse is it and secondly how could that fuse cause the heat to blow cold? I'm in no ways a mechanic I just want some info on the fuse and how it could cause the problem of blowing cold air.
  4. #4 Re: Heat
    GTX Level Member bronzemist02's Avatar
    Canada
    The fuse box in the glove compartment should say on it abbreviations for what the fuses are for. If the fuse is gone it wouldn't work on high at all because the power isn't getting through the circuit for it. The fuse is about $1, so it is a really cheap fix if it is gone. If it isn't the fuse it could be a resistor.
  5. #5 Re: Heat
    Charles City, IA
    Your heater core is plugged up.
    SMGPFC Two Nipple General
  6. #6 Re: Heat
    Dec 2008
    philly
    the fuse is why it wont work on high that solves your first issue.
  1. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  2. no heat
    By 71dang in forum General Tech Discussion
    Last Post: 10-28-2009, 12:34 AM
  3. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  4. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
