Thread: Vibrating issues
Results 1 to 8 of 8
  1. #1 Vibrating issues
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    04 gp gt... constant vibration in the steering wheel and gas pedal... happens on and off the gas... neutral and in drive... the worst when around 45 mph... I cant figure out what it might be... just started doing it all of a sudden... ne ideas, suggestions?
  2. #2 Re: Vibrating issues
    Cincinnati, Ohio
    bump... ive disected the problem more thoroughly... it is more of a wobble as if it is a flat spot in one of the tires... ne ideas?
  3. #3 Re: Vibrating issues
    West Side Michigan
    Check if one of the rims are bent. When I had a vibration in my car, it turned out to be the CV Axles.
  4. #4 Re: Vibrating issues
    MT
    Wierd, mine started doing this a few days ago. It was already scheduled for an alignment so when I took it in I had them check it out. Turns out both front wheel bearings were so wasted they couldn't do an alignment (and I wasn't getting any noise from them).
    I spent most of the day ****ing around with them and couldn't get my hub off. I'll try again tomorrow and let you know if it goes away. But if I replace these hubs and the vibs turn out to be a cv shaft I'll be royally pissed off.
  5. #5 Re: Vibrating issues
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    bent rim, weights fell off, flat spot. go get it checked or look urself
  6. #6 Re: Vibrating issues
    MT
    After replacing the tie rod ends and the passenger side bearing (I'm going to **** with the drivers side more today) my vibration issues went away.
    I'd guess it was the tie rod end doing it since the bearing had almost no play in it. The end was litterally a 10 minute job, only two tools you need is a socket for the nut on the bottom of the end, and a 22mm wrench to loosen the set nut.
  7. #7 Re: Vibrating issues
    Cincinnati, Ohio
    tire guy told me that the belts in the tires were either broken or moving... causing an egg shape... hence the wobble... replaced the tires and they told me my right outer tie rod was bad as well.. no more wobble though
  8. #8 Re: Vibrating issues
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Possibly a bent rim or worn hub as others had said. I let mine get to the point I had a 1" x 5" bare spot on the middle of the tire tread. You could see the air in the tire it was so bad. Rest of the tire had really good tread except that one spot. It was a front tire and could have been pretty nasty if a blowout would have occured. Good Luck!
  1. DLP tv issues
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 01-20-2010, 01:19 PM
  2. A few issues
    By Ellen in forum General Tech Discussion
    Last Post: 09-17-2009, 09:29 AM
  3. Pulling to the Ditch and Vibrating
    By Hawkins97 in forum General Tech Discussion
    Last Post: 08-05-2009, 02:16 AM
  4. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
  5. Car Vibrating badly
    By bcrosby51 in forum General Tech Discussion
    Last Post: 07-23-2008, 07:52 AM
