Thread: ECM To OBDII Connection
Results 1 to 14 of 14
lstexan ECM To OBDII Connection 01-30-2010, 05:45 PM
FoSHO99 Re: ECM To OBDII Connection 01-30-2010, 08:21 PM
TheOtherNick Re: ECM To OBDII Connection 01-30-2010, 09:24 PM
shawn3091 Re: ECM To OBDII Connection 01-30-2010, 11:01 PM
toolguy Re: ECM To OBDII Connection 02-02-2010, 07:23 AM
TheOtherNick Re: ECM To OBDII Connection 01-30-2010, 11:19 PM
JoshMcMadMac Re: ECM To OBDII Connection 01-31-2010, 08:57 AM
FoSHO99 Re: ECM To OBDII Connection 01-31-2010, 01:21 PM
TheOtherNick Re: ECM To OBDII Connection 01-31-2010, 03:24 PM
lstexan Re: ECM To OBDII Connection 01-31-2010, 08:38 AM
lstexan Re: ECM To OBDII Connection 01-31-2010, 01:40 PM
shawn3091 Re: ECM To OBDII Connection 01-31-2010, 09:39 PM
minichopper6hp Re: ECM To OBDII Connection 01-31-2010, 02:57 PM
TheOtherNick Re: ECM To OBDII Connection 02-07-2010, 03:05 PM
  1. #1 ECM To OBDII Connection
    SE Level Member lstexan's Avatar
    Pearland, Texas
    I recently bought a 98 GTP and the engine is running really rough, the SES light comes on and flashes sometimes. I plug in my OBDII scanner but it will not connect to the cars computer. The scanner will not even power up.
    I have checked the fuse in the glove box, it's okay, I recently bought a new ECM, still not connecting.
    Any other places to check?
    Thanks for your help.
  2. #2 Re: ECM To OBDII Connection
    Jan 1970
    Maquoketa, Iowa
    SES flashing means there is a bad misfire. Check wires/plugs/coils
  3. #3 Re: ECM To OBDII Connection
    Charles City, IA
    Grand prix's do not have power at the obdII port. Check and see if your scanner has a dead battery in it.
    SMGPFC Two Nipple General
  4. #4 Re: ECM To OBDII Connection
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    yes there is power at the obd port on a grand prix, mine has it anyways along with 2 grounds. i think it is tied into the cig lighter fuse
  5. #5 Re: ECM To OBDII Connection
    Guam
    My GM Tech II scanner gets its power from the OBD port on all cars, my GP too... I guess you are refering to aftermarket type scanners.
  6. #6 Re: ECM To OBDII Connection
    Charles City, IA
    No power to run the scan tool. They do not have that. That is why you have to run a power wire to an aeroforce etc.
  7. #7 Re: ECM To OBDII Connection
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    It powers my scan tool, and the LED lights up on my HPTuners MPVI when I plug it into the OBDII port.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  8. #8 Re: ECM To OBDII Connection
    Jan 1970
    Maquoketa, Iowa
    It's 01+ that do not have the power pinout on the OBD2 port.
  9. #9 Re: ECM To OBDII Connection
    Charles City, IA
    Quote Originally Posted by FoSHO99 View Post
    There we go. Coulda swore it was all of them.
  10. #10 Re: ECM To OBDII Connection
    Pearland, Texas
    I was told that the plugs and wires were most likely the cause for it running rough at idle, it smooths out at higher rpm. I will replace them.
    The power to the ecm port being tid into the cig lighter fuse is a possibility because that fuse blows. I will have to follow up on why that happens.
    Thanks for the advice and I'll get back.
  11. #11 Re: ECM To OBDII Connection
    Pearland, Texas
    It was the cig lighter, it shorted out somehow. I have disconnected it, no smokers in mt car - ha ha, now I can connect to car's computer. I got a PO 0303 code - #3 cylinder misfire.
    Thanks for all the great advice.
  12. #12 Re: ECM To OBDII Connection
    Jan 2009
    State College PA
    Quote Originally Posted by lstexan View Post
    i thought it was linked
  13. #13 Re: ECM To OBDII Connection
    Banned - Busted For Scamming
    Feb 2009
    Probably a wire. Yea its ran off the cig lighter fuse as you found out.
  14. #14 Re: ECM To OBDII Connection
    Charles City, IA
    I guess a modis could be considered aftermarket.
  1. internet connection
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 05-07-2012, 05:06 AM
  2. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  3. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
  4. Connection of Manual Oil Pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2008, 03:47 PM
