Thread: p0141 im stumped..
Results 1 to 20 of 21
  1. #1 p0141 im stumped..
    GT Level Member Joe m's Avatar
    mesa,az
    alright so i got this code 12/31/09 bank1 sensor 2 blah blah heated o2 sensor. so i replaced it. all was well until 1/15/10 when the SES light came back on. so had it scanned made sure it was the same code. ended up replace the 2 week old sensor with another one. well tonight boom same code again. i know this p0141 can not be tripped by the cat. so i know the cats not the issue. iv checked the fuses/relays everything is straight. from what iv seen there is no issue with any bad wiring running off the o2 sensor. any ideas of whats next!?
    edit- and im thinking the sensor is still good cuz my still averaging 22-23 on street and about 27-28 on highway.
  2. #2 Re: p0141 im stumped..
    mesa,az
    bump.
  3. #3 Re: p0141 im stumped..
    Cliffwood Beach ,NJ
    You checked the ign1 fuse under the hood? If thats good and the sensor is good then you have a wireing problem. Check for a rubbed through wire somewhere. Try in that tunnel heat deflector where the harness runs.
  4. #4 Re: p0141 im stumped..
    mesa,az
    iv checked that. and it all looks good. and yes last time i checked the fuse it was good. iv also heard of fuses going bad but not showing it? maybe i can try to replace the fuse and see if it changes lol.
  5. #5 Re: p0141 im stumped..
    hutto, tx
    just go to 3800 performance and buy an emulator 30 bucks and you'll never have to worry about that crap again. heres link
    Rear O2 Emulator: 3800 Performance
  6. #6 Re: p0141 im stumped..
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    you'll also never know if theres an actual problem related to that or your cat, if you go the emulator route
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: p0141 im stumped..
    mesa,az
    i know there isnt anything wrong with that cat. if there was a problem with the cat it would throw a p0410 or something. the p0141 has 0% todo with the cat. but when i get my headers i think im gonna get rid of the cat.
  8. #8 Re: p0141 im stumped..
    hutto, tx
    all the more reason to buy the emulator and really if a cat goes bad there is always the smell DUH if not then it would more than likely be completely plugged which i have seen cause retards thought they could use diesel to clean out injectors and they used to much xD classic mistake lol
  9. #9 Re: p0141 im stumped..
    Quote Originally Posted by Jesse1 View Post
    Unless your car is an 01+ and decides to run a diganostic on the cat and how it responds to different AFR's and then you run rich ALL the time.
  10. #10 Re: p0141 im stumped..
    hutto, tx
    lol not hard to notice and and reset pcm lol 5 minute job
  11. #11 Re: p0141 im stumped..
    And then it does it again?
    And again?
    And again...
  12. #12 Re: p0141 im stumped..
    mesa,az
    yea no kidding. ^ lol im trying to stop it from doing it again and again and again
  13. #13 Re: p0141 im stumped..
    PA
    What year car?
    2001 GSE
  14. #14 Re: p0141 im stumped..
    Nov 2008
    Fremont Nebraska
    that code means your sensor is bad, or there is a problem with the wiring going to the sensor. plain and simple. since you've tried 2 different sensors, we can probably rule that out (unless they're bosch sensors, then you may try 20 of them before you find a good one) i'd get a volt/ohm meter out and start diagnosing ALL the wiring
  15. #15 Re: p0141 im stumped..
    mesa,az
    its a 99, and yes they were a bosch: i havnt gone to dealer to get the oem one yet. and i will try the volt/ohm this weekend. what is a normal range for the wires? or is any power good.
  16. #16 Re: p0141 im stumped..
    Nov 2008
    Fremont Nebraska
    oh man. dont waste your time with the voltmeter now that you've said its a bosch. go to rockauto.com and get a denso and be done with it
  17. #17 Re: p0141 im stumped..
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    I don't know if this would apply to you but when I had that code the MAF sensor was dirty, a little electronics cleaner took care of the problem.
    edit: nevermind I was thinking of the P0171 code
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  18. #18 Re: p0141 im stumped..
    mesa,az
    the maf sensor? that has not a damn thing to do with the p0141 from my understanding? but hell ill try that to lol
  19. #19 Re: p0141 im stumped..
    I screwed up the numbers, sorry about that, I just looked at my service records and I was thinking about the wrong code.
  20. #20 Re: p0141 im stumped..
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    ur rear o2 is to tell if the cat is working or not.....nothing to do with ur gas mileage. turn it off or a simulator. done.
  1. p0141/o2 sensor questions
    By Jakegday in forum General Tech Discussion
    Last Post: 08-14-2011, 08:29 PM
  2. Code P0141 ???
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 01:18 PM
  3. Stumped
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 05:12 PM
  4. Need help! p0141 code.
    By rcweldon988 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:22 PM
  5. Stumped
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 09:34 PM
