Thread: how many gallons are our tanks?
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 how many gallons are our tanks?
    SE Level Member k5greek's Avatar
    Vineland, NJ
    I bought the gp as a beater and it gets decent mileage. I usually avg between 18-20ish mpg. The problem is I can only get maybe 200 miles out of a tank. I hate filling up so often.
    I looked up and saw that the cars came with an 18 gallon tank. Whenever I let the car run low and the fuel light comes on I dont think Ive ever put more than 12-14 gallons in.
    Even if I got 15 mpg with 18 gallon tank I should be able to go 270ish on a tank. when i hit 200-220 my light comes on. Whats up? Did these cars ever come with a smaller tank for some reason?
    Car is a 98 GP GT
  2. #2 Re: how many gallons are our tanks?
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    Do you calculate ur mileage? Or go by the monitor? And yes 18 gallon tank. My moniter shows 20ish and I get like 15-16 actually
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  3. #3 Re: how many gallons are our tanks?
    Vineland, NJ
    Do it on my phone everytime I gas up. No monitor for me.
    Even if I only got 15-16 I should still be able to get more than 200 miles out of a tank.
  4. #4 Re: how many gallons are our tanks?
    Waterloo, Iowa
    Hmmm ya idk I got 220ish on my last tank. I don't remember how many gallons it took to fill tho
  5. #5 Re: how many gallons are our tanks?
    GTX Level Member cerick08GP's Avatar
    My guess is the fuel gauge is off. I had a Buick once that could be bone dry, and the fuel gauge would show over ΒΌ tank.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: how many gallons are our tanks?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I noticed the same thing when I bought my 03 GT 4dr. After putting almost 40,000 miles on it, I think there is more fuel in the tank than the gauge shows. I have never put in more than 15? gallons in it.
    If you are dividing miles by the number of gallons at the next fill up-that is your mileage. Go as long as you want on E at your own risk.
    In the mid 90's, I had a 88 Buick Regal Limited without a working odometer and fuel gauge! BAD COMBO!
  7. #7 Re: how many gallons are our tanks?
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    I don't really know exactly how many miles I can go because my fuel gauge is broke, it works but once the gauge goes down to 1/4 it start going up until it read full. So I normally fill up when the gauge reads 1/4 just in case, I can drive 300 miles, I'm sure I can go more but I don't want to risk since the gauge don't work good
  8. #8 Re: how many gallons are our tanks?
    apparently 97 is 18 gallons and every other year after is 17.5
    Forget where i heard that though
  9. #9 Re: how many gallons are our tanks?
    MO
    06 is 18 just for reference^
    Anyways, don't forget about the reserve on the tanks. Even when mine is almost on empty I still have 2-3 gallons left. Granted, that shouldn't matter if you calculate mpg right. After dealing with bad gas gauges in all 3 GM cars that my family owned (2000 chevy blazer, 2001 olds silhouette, and 2002 saturn L200), i wouldn't trust the gas gauge to ever be right.
    <brandonl2000> LMAO D!!
  10. #10 Re: how many gallons are our tanks?
    Topeka, KS
    I know this sounds bad but when i've been low on dough i've ran my car past E several times and still had gas to make it to work until my next paycheck came. The most i've ever put in the car was 15-16 gallons and it seemed like it took forever to fill up. The light comes on when you have drank about 12-13 gallons it seems like.
  11. #11 Re: how many gallons are our tanks?
    PA
    GM lists the fuel tanks to be 17.5-18 gals. Not sure if that is without the fuel pump in it. Or just the tank. Regardless, that is the size.
    For me, my light comes on when I have used around 13 gallons. But I can easily keep driving and put 15 gallons in or so. The tanks have a reserve and the light comes on early so you don't run out. Typically I get 320-360 miles on a tank. I just filled up last night with gas and put in 14.3 gallons, and had 347 miles on the odometer.
    2001 GSE
  12. #12 Re: how many gallons are our tanks?
    Vineland, NJ
    Yea I forgot about the reserve. I think I may try to go a little further and see how that goes. Just not sure by how much.. Maybe ill try 250-275ish and see what happens.
  13. #13 Re: how many gallons are our tanks?
    GT Level Member BoostedComp's Avatar
    Youngstown
    hmm i thought it was a 17 gallon tank... lowest i ever got was on a road trip home.. there hasnt been an exit is almost 20 miles i finally got to one and put 16.4 gallons in... talk about thirsty
  14. #14 Re: how many gallons are our tanks?
    SE Level Member tigger's Avatar
    london ky
    i usually average about 3oo on 14 gallon but like everybody else the most i ever put in was 14.7 so ive never trusted it past 300 -310
    Stock 2000 GT With High Hopes...Sony Xplode cd with 2 Cerwin Vega 6x9s in the rear 2 6''Sony Xplode in the doors, 2 Lanzar Max pro 12" subs with Boss D800.2 1600 watt 2 channel amp in the trunk. more to come
  15. #15 Re: how many gallons are our tanks?
    SE Level Member Gmohre001's Avatar
    Harrisburg NC
    I made it too 330 miles on my way to school and ended up running out of gas..... my gas guage doesnt work..
  16. #16 Re: how many gallons are our tanks?
    Norristown, PA
    i put 9 gallons in my tank today and its almost full
  17. #17 Re: how many gallons are our tanks?
    Quote Originally Posted by rocafella2032 View Post
    ??? Your tank was not completly empty? a little over 1/4? that is kinda weird, it takes more than that to get a full tank unless your tank was not low. I've put like 11 when my gas gauge shows 1/4
  18. #18 Re: how many gallons are our tanks?
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    ok not to bump an old thread, but when I fill up my tank when my gauge is completely on E, I can never put more than 12.3 ish gallons in. If we have a 17.5 gallon tank, does that mean my gauge is essentially broken? I find it odd that my gauge will read all the way from empty to full but I can only put in 12 gallons.
    2006 Mitsubishi Evo IX MR
  19. #19 Re: how many gallons are our tanks?
    there IS a dead zone but when mines LOW i can put around 55 litres in.
    thats 14.5 gallons.
  20. #20 Re: how many gallons are our tanks?
    sh1t.
    I've put in 16 week after week...but my buddy never puts in more than 13 gallons and he can have the light on and I'll be around an 1/8. I hate these cars.
  1. Are you interested in Fish/Reef/Invertebrate etc. Tanks?
    By Quicklynx in forum Off Topic Discussion
    Last Post: 04-06-2009, 10:03 PM
