Thread: Is it possible to install remote starter and use Fob from 2005 on GP GT2 2004?
Results 1 to 4 of 4
  1. #1 Is it possible to install remote starter and use Fob from 2005 on GP GT2 2004?
    SE Level Member bat00's Avatar
    Iowa
    Hi, I am a new guy. Just bought GP GT2 2004(first time Pontiac owner) and like it a lot. The only thing is missing is remote starter. I know you can install off market one. But I saw the 2005 fob that has 5 buttons. So my question is: is it possible somehow use that fob with my 2004 and add remote start option? Can I install that remote starter (or package) from 05 on my 04? Any input is appreciated. I am willing to try anything that does not require expensive equipment. I would install it myself if possible. My budget is up to $150, but would like to spend less. If I need to see dealer to program a new Fob I will. If I cannot use 05 Fob, please recommend a good inexpensive remote starter/keyless entry kit/system that would lock, unlock, open trunk, have panic button and start the car.
    Thanks
  2. #2 Re: Is it possible to install remote starter and use Fob from 2005 on GP GT2 2004?
    New Brunswick
    I got the factory remote setup i took from a g6 and have it in my 04, the door locks and everything works with extended range, but i still have to get an 05 bcm with the same options as mine + remote start so that the remote starting will be supported. As for the hood switch for the factory setup a resister will make it think there is one, forget the exact value but i will let you know as soon as i can find a bcm to try it.
  3. #3 Re: Is it possible to install remote starter and use Fob from 2005 on GP GT2 2004?
    Iowa
    Let me know how it works out. Also, if I switch bcm wouldn't I loose original mileage?
  4. #4 Re: Is it possible to install remote starter and use Fob from 2005 on GP GT2 2004?
    New Brunswick
    The mileage on the display would not be affected, but the mileage stored in the bcm itself will be different.
    I will let you know as soon as I can find an 05 bcm and give it a try to see how it works.
  1. Valet 552t remote starter question
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-27-2009, 09:40 AM
  2. remote starter issues
    By COI in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2009, 11:09 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
