Thread: Domelight over ride?
Results 1 to 7 of 7
  1. #1 Domelight over ride?
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    Hey guys, does anyone know if there's a possibility to hook up a switch to kill the interior lights? It'd b sweet if I could figure something out and I've searched a little but haven't come up with any solutions yet. I'm sure other people have been wondering bout this too and think it'd be a great mod to our cars. Thanks!
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  2. #2 Re: Domelight over ride?
    Feb 2010
    egg harbor twp
    did you get any help yet i have a 1993 grand prix gtx that has the same prob or atlest it sounds like it i replaced the handle and now it wont turn off but the handle works prop.
  3. #3 Re: Domelight over ride?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    hook in a switch in between the interior fuse, or splice a switch into the headlight switch to the interior lights
  4. #4 Re: Domelight over ride?
    Feb 2010
    egg harbor twp
    i think i have anther idea to get it to work properly if and only if the switch has to be grounded out you can run the ground to the door switch ground so it will still activate the lights when the door is opned w/o the nucences of having to flip a switch everytime you need to turn on the lights
  5. #5 Re: Domelight over ride?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    yes! the wire you're looking for is in the drivers side kick panel, at the BCM. theres 2 connectors plugged into the BCM, 1 with 8 thick wires and 1 with 32ish thin wires. in the harness with the 8 thicker wire, the DARK BLUE wire is listed as "courtesy lamps supply voltage" in my factory service manual, so i believe thats the wire you'll wanna put a toggle switch in between
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: Domelight over ride?
    McKinney, TX
    its simple. my gp does the same thing. just slide the knob (the one that slides from L to R, located under the light switch) all the way to the right,, until it clicks, then slide it back. so every time you close the door, or just open and shut it for a second, just rememder "slide Right, click, slide left), and the lights shut off automatically and stay that way as long as you keep the door closed.
    2002 GP GT 3.8 N/A, tined head/tail lights, brakelamp/LP lamp/taillamp toggle switch
  7. #7 Re: Domelight over ride?
    Waterloo, Iowa
    hm ill have to remember that. thanks
  1. sh!tty ride
    By badbrad in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2010, 11:20 PM
  2. my ride
    By echarleswhyte in forum General Tech Discussion
    Last Post: 09-10-2009, 05:12 PM
  3. bad ride
    By badbrad in forum General Tech Discussion
    Last Post: 03-06-2009, 11:24 PM
  4. My Ride
    By Dizave in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:55 PM
  5. Got a New Ride.
    Last Post: 01-13-2008, 04:19 AM
