Thread: 04 gtp supercharger
Results 1 to 7 of 7
  1. #1 04 gtp supercharger
    alabama
    Is it possible for the supercharger to throw oil into the coolant?Also the supercharger is making a whining noise .
  2. #2 Re: 04 gtp supercharger
    supercharger that makes a whining noise?
    really. hmmmmmmmmmmmmmmmmm...I'll have to look into that.
  3. #3 Re: 04 gtp supercharger
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    Superchargers whine? Never thought id live 2 see the day. Lol. You serious? Also your s/c oil should be sealed in the snout. I see no way it could make it in2 your coolant.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: 04 gtp supercharger
    alabama
    Yeah a whine!like bad bearing.
  5. #5 Re: 04 gtp supercharger
    GEORGIA
    S/c whine, thats what they do. I was being sarcastic.
  6. #6 Re: 04 gtp supercharger
    Portland Oregon
    It's more likely that your lower intake manifold gaskets are leaking. As far as the bearing whine coming from the supercharger, take the s/c belt off and see if it goes away. It's probably a snout bearing.
  7. #7 Re: 04 gtp supercharger
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    If you want a rebuild or porting for your supercharger call Stiegemeier Porting Svc. www.Stiegemeier.com or 636-949-2275. They do great work and have a super quick turnaround time.
  1. Supercharger
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 06:24 PM
  2. supercharger oil
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 01:29 PM
  3. supercharger
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 07:30 PM
  4. Supercharger oil.. how often?
    By bentendo92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 06:33 PM
