Thread: Failed emission test again.
Results 1 to 9 of 9
  1. #1 Failed emission test again.
    Mesa, Arizona
    Found a defective PCV tube that was letting air leak in. Replaced and the car's idle dropped to normal speed and the car ran much better.
    Hydrocarbons had been 2.36 on the first test with the passing standard being .80. Second test the hydrocarbons dropped to 1.9.
    What else?
    PCV itself?
    Catalytic Converter?
    Upper Intake Manifold gasket?
    Lower Intake manifold gasket?
    Plugs?
    All the above?
    Any suggestions would be GREATLY appreciated. Registration expired 11-30 and pretty soon the cops will be pulling me over! :-(
  2. #2 Re: Failed emission test again.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    A high HC reading is the result of poor combustion. The most typical cause is a poor ignition system. HC is nothing more than fuel that makes it out the tailpipe without being burned.
    Are the plugs old? are the wires old? Could be a vac leak aswell. Do you have a Scan gauge?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Failed emission test again.
    Mesa, Arizona
    Quote Originally Posted by 01gpgt01 View Post
    The plugs and wires are at least 5 years old, about 50,000 miles ago. Do not have a Scan gauge. What does a Scan gauge do?
  4. #4 Re: Failed emission test again.
    vac would lean it out wouldnt it?
  5. #5 Re: Failed emission test again.
    Mesa, Arizona
    Could be vac leak but where?
  6. #6 Re: Failed emission test again.
    correct vacuum leak would lean it out...
  7. #7 Re: Failed emission test again.
    Hagerstown,Md
    What happens to the fuel trims when you have a vacuum leak.? They max and it dumps fuel.
  8. #8 Re: Failed emission test again.
    true...
    Check the vacuum lines on the top of the engine.
    There aren't many.
    Just start spraying carb cleaner around and if the engine speed lowers then you've found it.
  9. #9 Re: Failed emission test again.
    Mesa, Arizona
    Thanks
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. failed lim gaskets and you
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-29-2010, 01:11 AM
  3. california emission
    By musiknjoyr in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-20-2010, 11:05 PM
  4. yippie pass the emission test
    By nemesis in forum Off Topic Discussion
    Last Post: 07-04-2008, 03:44 AM
  5. Emission Codes: PowrTuner users
    By fst in forum PCM Tuning
    Last Post: 01-24-2008, 07:44 AM
