Thread: power steering?
Results 1 to 6 of 6
  1. #1 power steering?
    SE Level Member X97prixX's Avatar
    Idaho
    every once in a while when I give the car gas and turn the car the power steering cuts out. I had it once even when I braked hard and then turned it cut out with a squeal. Power steering is full, I had it leaking a little a while ago but nothign lately. So I don't know what to think "Bad pump?"
  2. #2 Re: power steering?
    PA
    Quote Originally Posted by X97prixX View Post
    I would say bad rack.
    But I would also make sure to check your fluid again. If you had a leak, and did nothing, you probably still have a leak.
    2001 GSE
  3. #3 Re: power steering?
    Idaho
    I'm thinking your right. Just to make sure I was looking at it tonight up on the lift and underneath the powersteering pump is the Rack and pinion right? (just making sure I've never really had to deal with one.) If so it was covered in fluid that looked like power steering fluid, not sure though. any thoughts?
  4. #4 Re: power steering?
    PA
    Sounds like you are leaking PS fluid. Find out where, and fix that. Could be the PS Pump, feed line, return line, or rack. Any and all of them have fluid and are known to leak.
    2001 GSE
  5. #5 Re: power steering?
    Idaho
    How much does it cost for a new rack?
  6. #6 Re: power steering?
    PA
    Depends.
    If you go with a brand new one installed by a garage, you are probably looking at $500-$600, my guess. If you do it yourself, probably $250-$350, with a new rack.
    For me, I had heard about the issues that people have had with rebuilt racks. So I bought a good used GM one from Morad Parts Company and haven't had any issues with it at all. I installed that probably 70k miles ago. I also did the PS pump and lines at the same time. Everything was less than $150.
    2001 GSE
  1. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
  2. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  3. power steering
    Last Post: 04-11-2009, 10:52 PM
  4. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  5. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
