Thread: P1811 Code Transmission 91,000 miles
Results 1 to 10 of 10
  1. #1 P1811 Code Transmission 91,000 miles
    Waterford, MI
    I have a 2005 Pontiac Grand Prix GT. The car shifts hard from 1st to 2nd and 2nd to 3rd once in a great while. If I stop and shut the car off and start it again it goes away. The car did produce a code of P1811. The vehicle has 91,000 miles on it and I have not changed the trans fluid yet. I have been told it is one of three problems.
    The silonoid needs to be replaced: about $500
    The trans need to be rebuilt: about $1400
    The ingition is going bad: not sure on the amount
    I just want to fix this once, with the info I gave above can anyone point me in the right direction.
    Thanks,
    Jeremy
  2. #2 Re: P1811 Code Transmission 91,000 miles
    Des Moines, Iowa
    Mine (03 GTP) is doing the same exact thing. havnt looked into it. the dealership i bought it from a year ago says they changed the trans oil and filter so i havnt yet. id also be pretty interested in knowing some other peoples opinions.
  3. #3 Re: P1811 Code Transmission 91,000 miles
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    post this in the transmission section, or pm trannyman, he's the trans guy around here
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: P1811 Code Transmission 91,000 miles
    Jul 2008
    sumter,south carolina
    p1811 is max adapt long shift... 99.9999percent of the time its a bad pressure control solenoid... pretty easy fix if u have mechanical knowledge or about 250-400 bucks if u dont.
    02 GTP with mods 05 GP for DD
  5. #5 Re: P1811 Code Transmission 91,000 miles
    Sep 2013
    Warren, MI
    I have been reading about this on the forum. I got an 04 gtp about a week ago. I didn't notice until I tried tried to pass on the interstate that it would shift haed from 4th to third, and had the code checked, and sure enough it was a 1811.
    My question is do you replace with the Delco part or is there a better alternative since the delco solenoid seems to do this a lot?
  6. #6 Re: P1811 Code Transmission 91,000 miles
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    What about the transgo shift kit? I used the kit because I had the same code, Its been a year no problems yet..
  7. #7 Re: P1811 Code Transmission 91,000 miles
    Sep 2013
    Warren, MI
    Did you have the same problem I described, or just the same code? I ask because I only have problems downshifting from 4th tho third, and what I read says the kit helps with shifts from 1-3, but the shift I need to happen faster would be from 4th/overdrive to pass? If you had the same experience and the shift kit helped that, I would feel a lot better about installing it.
  8. #8 Re: P1811 Code Transmission 91,000 miles
    Aug 2012
    Chicago
    Ok I got cha. Your probably right, I had problems from 1st to second gear..at around 30 mph it would buck very hard, at the same time the trans pump would start to wine, only when the car was hot. Those were my symptoms and I had that same code. Your problem , I think the kit addresses, cant remember exactly, but the part for that is installed through the side cover.
    Have you tried some Sea foam Trans tune?
  9. #9 Re: P1811 Code Transmission 91,000 miles
    Sep 2013
    Warren, MI
    I will when i change the fluid. I an going to install the kit and see what it does, if i have to go in the side cover i will go ahead and do the solenoid
    Sent from my SGH-T989 using Tapatalk 2
  10. #10 Re: P1811 Code Transmission 91,000 miles
    Guys.. ancient thread.
  1. Transmission Code and no 4th gear HELP
    By JunkboxGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:03 AM
  2. P1811 will not go away
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 06:16 PM
  3. p1811 max adapt-long shift
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2008, 03:21 PM
  4. P1811 code (maximum adapt and long shift)
    By DuBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 09:46 PM
  5. How many miles is to many?!
    By Ninjo in forum Off Topic Discussion
    Last Post: 06-29-2008, 08:17 PM
