I have an 04 GT1. 52,000 miles. The HVAC blower motor will go through all the speeds on the speed controls. The issue is when it is on full speed as far as I can tell. It will blow like it should then if I put the car in drive and move the speed will slow down when I let of the gas, when I give the car gas it will go back where it is supposed to be. Is this a possible symptom of a bad blower resistor? I replaced the battery recently. I thought this problem was related to a bad battery but it continued. The battery was bad though. Can I test the resistor? Di I remove the cowl on the pass side to replace the resistor? I need to fix the cowl leak anyway.
