Thread: Header and manifold Thread
Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 281 to 300 of 325
  1. #281 Re: Header and manifold Thread
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    Yeah I guess it kinda would lol. That would be a lot of metal lol
    97 GTP. ZZP CAI, ZZP Custom Dyno Tune, Drilled 180* Tstat, Voltege Booster, A104's, ZZP Wires, 3.4 Pulley, ZZP Stainless Headers with TOG down pipe, ZZP 3 inch Stainless Cat Back.
  2. #282 Re: Header and manifold Thread
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    will ebay headers bolt on to my zzp 3'' down pipe?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  3. #283 Re: Header and manifold Thread
    Out West
    NOPE.
    Whine with your Cheese?
  4. #284 Re: Header and manifold Thread
    Jul 2010
    Montreal
    Alright so what i understand with the SD headers, ill need new gaskets (front-back-down pipe catback)?
    New clamps? or use the same clamps and seal them up with RTV?
    and i got lost with the down pipe part... I need to get a custom one? what do i have to do exactly? and whats the size 2.5''?
    those?
    http://www.ebay.com/itm/97-08-GRAND-...item3a7118c532
    or those?
    http://www.ebay.com/itm/97-03-04-08-...item2c634a220d
  5. #285 Re: Header and manifold Thread
    Charles City, IA
    You need 2-2.25" bandclamps, and one gasket for the cat back.
    SMGPFC Two Nipple General
  6. #286 Re: Header and manifold Thread
    Jul 2010
    Montreal
    alright so one gasket for the catback,
    and what about the down pipe? do i need a o2 sensor entension? sensor1 or sensor 2?
  7. #287 Re: Header and manifold Thread
    Need an extension for the upstream o2 and the downpipe is part of the headers
  8. #288 Re: Header and manifold Thread
    Charles City, IA
    You need an extension for the front.
  9. #289 Re: Header and manifold Thread
    What trashcat said.
    And make sure the wires and stuff are out of the way and wont touch the hot headers or this will happen and you will be boned and need a new 02.
  10. #290 Re: Header and manifold Thread
    Jul 2010
    Montreal
    alright sounds good, will i have any problem fiting the dp?
  11. #291 Re: Header and manifold Thread
    With SD Headers you need/want:
    2 x 2.25" band clamps
    2 x 3.00" band clamps
    I prefer to get them from FrozenBoost.com as they are $5 each and the shipping is pretty quick.
    The SD's do not have a cat in them. I would suggest getting a 3" high flow. You may want more 3" clamps as the SD headers come with a straight pipe where your cat currently resides.
    SD's do have a rear O2 bung in the same place as your 97-03 car.
    SD's will require an O2 extension, extending the O2 wires or getting an O2 with longer wire (Bluegtp91 knows the part number)
    SD's will usually require you to move the edge of the tunnel/firewall for O2 clearance.
    I install a lot of headers for people. The only time I use RTV is on TOG's because their donut style setup often leaks. All slip fit headers do not give me leaks. I install the rear fully. The slide the crossover into it and as the front is installed I tap the crossover near the front to crossover connection with a rubber mallet to seat the pipes together. Once clamped, there's not a leak.
    For more tips/tricks, please see the "How to install headers (the easy way)" thread
    Have you ever checked months later for carbon build up?
    I've never had any slip fit joint seal without rtv.
  13. #293 Re: Header and manifold Thread
    Jul 2010
    Montreal
    thanks! I read the DIY and it helped out!
    and My engine is from a 2000 GTP do i need a CAT? or i can keep it catless?
  14. #294 Re: Header and manifold Thread
    You need a cat if you have emissions testing
  15. #295 Re: Header and manifold Thread
    SE Level Member crysalis's Avatar
    Mentor, OH
    Has anyone tried ZZP's "Pro Kit" for pacesetters?
    I'm lookin to do an upgrade, but not sure how far I want to go. I thought about doing headers, but if the front PLOG is all that really matters on 04+ (is it since we don't have the u-bend?), why not just do that and leave the rest stock? I'm in Ohio and we have to have a cat. I don't think i'll be doing any other upgrades (unless somehow I can support a smaller pulley) other than this as I'm buying a house soon and a child/spawn will shortly follow... not to mention... I have a wife watching the bank account
    2006 GP GT S/C | CAI | Overkill PCM | PLOG | 3" Catted DP | ZZP Strut Brace -- SOLD the car in treason for a Hemi Charger >:]
  16. #296 Re: Header and manifold Thread
    There must only be a few counties in oh that have emissions. I don't
  17. #297 Re: Header and manifold Thread
    Mentor, OH
    Yep... Lake county here.
  18. #298 Re: Header and manifold Thread
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
  19. #299 Re: Header and manifold Thread
    junk.
    looks like pacesetter knock off thingys.
    buy speed daddys.
  20. #300 Re: Header and manifold Thread
    Sep 2011
    Vancouver
    i was planning on getting speed daddys but will i have any issues with the bend thing since i'm lowered on eibachs and soon coilovers?
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
