Re: Header and manifold Thread
My down pipe fix. for the ssac and speed daddy headers
http://i426.photobucket.com/albums/p...g?t=1296612299
http://i426.photobucket.com/albums/p...g?t=1296612352
http://i426.photobucket.com/albums/p...g?t=1296612376
I just crush bent a piece of 2.5" to use for now. The degree of the bend is 65*. Right now I have no flange at the rear header, I will probally just drop it out the bottom when I ever need to pull the header. The reason I used 2.5" is because we had some laying around the shop so it was free.
what a beautiful pieve of work. just flawless
the bottom of the clamps are even with teh bottom of the tunnel, it is tucked up better than stock.
so now i dont need the SLP's? :p
I have no way of welding yours in unless we pull the rear header.
whoa whats diff between mine and yours :p
I have been reading arround and people have said that SD headers are no good for droped people, is this true? I dont feel like reading the whole 10 pages to see if someone asked the question before lol
Some say the lil dip in the dp can hit **** but I dunno. Don't drive like an idiot and you'll be fine.
im really easy on bumps and pot holes so i shouldnt be sacred of braking something with the sd headers and eibach drop?
hopefully you dont do speed bumps.
try having a 2 inch dropped t/a with headers and custom true duals, theres about an inch of between the ground and the piping. a rock in the road would hit that sh!t
biggt
im going with the same drop and headers. im planning on haveing an exhaust shop re do the dp to reduce the bend. like what 01gtp posted up above
So who wants to be the Guinea Pig and buy a set of these.
97-08 GRAND PRIX BUICK REGAL 3.8L V6 HEADER EXHAUST - eBay (item 350436066265 end time Feb-05-11 09:06:07 PST)
Im confused as to why there is a 14" section of rubber hose and a bunch of hose clamps. :confused:
those dont work.
crossover is wrong.
Why the hell did the SD header manufacturer design that U bend in there, anyway? The stock GP U bend protects the O2 sensor, which makes sense.
Its really too bad that a guy has to replace the U bend, replace the flex, buy better quality gaskets, buy different clamps, and still pray that the SD's will work. I guess that is why we say "you get what you pay for".
mechguy
They were designed like SLP's which also has the u bend. The u bend only needs replaced if you are dropped or dropping.
My flex is fine, my gaskets are fine and I only replaced the 3" clamps. Mine work great. I'm not complaining.
even ZZP's have issues.
no 100% perfect header for our platform
so after reading everything im still confused to as what you all need for speed daddy headers.
If you get em in the mail what are the things you need to buy?
"band clamps" ,
And so they do have a U-Bend? it doesnt say it as a "con" for SD headers so i was confused.
Sorry still a newb at this header stuff. lol.
I have no idea what to buy, cause they all have problems.
Also.. do i need to buy a dp with cat?
or can i just buy a new highflow cat that can be welded onto the pipe?..
