Thread: Anti Freeze Leak
Results 1 to 4 of 4
  1. #1 Anti Freeze Leak
    Feb 2010
    West Virginia
    Hey 2 months ago I had to replace the 2 plastic hoses in the pulley assembly. A couple weeks after that, I started noticing everytime I made a hard right turn I was getting smoke coming out from under neath the hood. I could smell anti freeze everytime this happen. There are no visual leaks under the car but there are stains on the left side of the motors exhaust manifolds from the anti freeze. Could this be residual from the line replacement or do I have another leak.
    Thanks
  2. #2 Re: Anti Freeze Leak
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Did you make sure you got all the o-rings in the new elbows, and that they were seated properly? If there were any parts left from the old elbows (which is likely), they could also be preventing a good seal.
    Try revving the motor while you're looking under the hood. The increased pressure as you rev the engine may allow you to see where it's leaking from.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  3. #3 Re: Anti Freeze Leak
    Feb 2010
    West Virginia
    Thanks for the reply. No, the elbows are both dry. Also, no noticable leak on engine run. When I get the smoke from the antifreeze, it is running onto the front, left bank, exhaust manifold.
    Thanks
  4. #4 Re: Anti Freeze Leak
    GTX Level Member Deimos's Avatar
    iowa
    Did you check the intake? Also hook up a presure tester and see if it holds pressure or starts pissing out somewhere/
  1. Oil "Leak"/Anti-freeze dump
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 08:06 PM
  2. anti rattle spring
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2009, 12:02 AM
  3. Anti Rattle Clips
    By My '08 GXP in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 08:42 PM
  4. pop up anti virus download
    By nemesis in forum Off Topic Discussion
    Last Post: 04-10-2008, 09:24 AM
