Thread: Need help now!
Results 1 to 13 of 13
  1. #1 Need help now!
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    Hey guys, so i barely even took my car out of the garage today but i did and it drove perfect, and the second time i took it out it started up fine and then put it in R and all was great. I then backed out of the garage and threw it in D like i always do and its like it went to N, there was nothing. I put it in 3 and again nothing, and then i tried 2 and it goes but shudders and 1 works the same way. Also, if i get some speed up, you can upshift to 3 and it will work as long as you keep speed up..what is with this?
    Do i need a new transmission filter or is it a Torque converter?
    The tranny has never had any issues other than this, it doesnt shift hard even with this problem.
    Also the tranny fluid looks pretty clean, any advise is much appreciated!
  2. #2 Re: Need help now!
    Charles City, IA
    IIRC you probally broke the forward band and the manual band is allowing you to use 1,2,3.
    SMGPFC Two Nipple General
  3. #3 Re: Need help now!
    Dec 2008
    Cedar Rapids, IA
    what are the bands, and where are they?
  4. #4 Re: Need help now!
    Charles City, IA
    They go around the drums that hold the clutch packs in side the trans.
  5. #5 Re: Need help now!
    Dec 2008
    Cedar Rapids, IA
    exspensive to fix then?
  6. #6 Re: Need help now!
    Charles City, IA
    New trans or full rebuild. I would talk to tranny man. Remember I am not 100% sure that is your problem.
  7. #7 Re: Need help now!
    Dec 2008
    Cedar Rapids, IA
    i mean it doesnt even try to go into D, it doesnt move the car like it usually does. Its just like its an exstension of N
  8. #8 Re: Need help now!
    Charles City, IA
    Thats because the band is not clamping around the drum the drum just spins and does to send the power anywhere.
  9. #9 Re: Need help now!
    swift current,sask.
    Yep, your going to need a full rebuild. Mine did the exact same thing as yours did.
  10. #10 Re: Need help now!
    Dec 2008
    Cedar Rapids, IA
    oh fun
  11. #11 Re: Need help now!
    Dec 2008
    Cedar Rapids, IA
    how much that cost you?
  12. #12 Re: Need help now!
    Apr 2009
    stockton ca
    I have one in my garage im going to rebuild and parts alone can get up and over 600 depending on what you replace and such
    Talk to trannyman(triple edge performance) he can hook you up on every thing you could want for a trans rebuild or a new built trans
  13. #13 Re: Need help now!
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    sorry to hear about that man, i know i'm on borrowed time too. tep will be who i talk to also, good luck
