Thread: Air Fuel Ratio
Results 1 to 8 of 8
  1. #1 Air Fuel Ratio
    GT Level Member rolyat's Avatar
    OKC
    I've noticed a lot of guys who mod their gtp's get wideband afr O2 sensors, and I was just wondering if it is absolutely necessary. I know running lean is dangerous, but wouldn't you have excessive KR if you're running lean?
  2. #2 Re: Air Fuel Ratio
    Jan 1970
    Maquoketa, Iowa
    Not necessarily, you could run lean and still have no knock.
    I would invest in a wideband if you are pushing around 300whp or going for 12's. But its really up to your budget.
  3. #3 Re: Air Fuel Ratio
    Donating Users blowfishRus6's Avatar
    g.a.
    i knocked a good bit with my canned intense tune when it was running really rich. made a commanded A/F ratio change and alot of the knock went away.
    if your serious about tuning and would like to keep a check on it at all times, i would get a gauge. you can see what the fuel is doing via tuner, some dont even need a wideband to tune, but its not quite as accurate.
    its something handy to keep an eye on.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: Air Fuel Ratio
    Donating Users chrisb's Avatar
    Bucyrus, OH
    like what was stated above running lean wont necessarily cause knock. it will get you closer to the knock threshold. the correct afr has one of biggest impacts on how much if any knock a engine will see. its a delicate balance of afr, timing, and airflow. and other stuff if you want to get specific.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  5. #5 Re: Air Fuel Ratio
    OKC
    okay, I'm not getting too serious with my car just looking to get around 250whp or so. I still don't know if I want to get hptuners or overkill but either way my afr shouldn't get so out of whack that I could justify buying one. I mainly just want to keep my engine safe.
  6. #6 Re: Air Fuel Ratio
    g.a.
    well with out a tuner, if your A/F is off, you cant really adjust it. you would have to send your pcm off and find someone with a tuner.
    a tuner really pays itself off in the long run.
    its slow.
  7. #7 Re: Air Fuel Ratio
    OKC
    Quote Originally Posted by blowfishRus6 View Post
    Very true.
    I'll probably get the wideband if I go with the tuner and just won't get it if I go with the Overkill pcm.
  8. #8 Re: Air Fuel Ratio
    an m90 car running at 12.0:1 AFR with a bunch of boost knock free is FAST.
  1. Gear Ratio Pro's and Con's
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 03:02 PM
  2. Gear ratio adjustments
    By Sabrewings in forum PCM Tuning
    Last Post: 04-08-2009, 06:02 PM
  3. air fuel ratio ?
    By eddie97gt in forum General Tech Discussion
    Last Post: 02-17-2009, 05:46 PM
  4. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
