Thread: too small of a s/c belt???
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: too small of a s/c belt???
    Bastard Reptile's Avatar
    Kansas City, MO
    Suggestions as far as what? IF the rotors are indeed bad, it's as simple as replacing them. It happens unfortunately. But the good thing is, you can replace them with the blower still on the car.
  2. #22 Re: too small of a s/c belt???
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by Reptile View Post
    Those are rotors I got from ED a little over a year ago. I put a new coupler in in October when I a tripleedgeperformance ported blower (my housing btw).
    Well I'm gong to pull the snout tonight. I guess I'll have to ask questions once it's apart.
    I still have the anaerobic sealant, not sure if I have the proper high temp grease of not. What are the tq specs for the snout bolts?
    arrgghhh I guess I should get another coupler to put in while I'm at it.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #23 Re: too small of a s/c belt??? UPDATE
    St Louis MO
    UPDATE After disconnecting the battery, removing the hold down nuts on the fuse box, and taking off the two belts I grabbed a hold of the pulley to take it off. There was NO noise as a result of rocking the pulley back and forth. I then removed the oil fill bolt to check the oil. The oil was full and clear as the day I filled it in October. It didn't smell bad or taste too bad either. Anyway I rocked the pulley back and forth with the fill bolt out to allow better chance of hearing the clunking. Nothing.
    The only difference between yesterday and today was that the blower was completely cool tonight after sitting 24 hours, where last night it was still quite warm from the 26 mile trip home from work.
    SO other than the ZZP coupler that's in there what else could change shape enough from heat to make a clunking noise? I've not really noticed any strange noises while driving and I'm not getting any KR from the clunking, if it's clunking while the engine is running.
    2010 Camaro SS LS3
  4. #24 Re: too small of a s/c belt??? UPDATE
    Kansas City, MO
  5. #25 Re: too small of a s/c belt??? UPDATE
    St Louis MO
    I know. Someone much have broke into my garage while I was at work and fixed whatever it was...actually the bad part is, I'm sure I'll find it doing the same thing once hot. Why? Because now that I know there is clunk potential, I'll constantly be popping the hood and shaking the pulley. I can't help myself.
    2010 Camaro SS LS3
  6. #26 Re: too small of a s/c belt???
    St Louis MO
    I need to get the car put back together quickly and need to know something about tolerances. After pulling the snout, it seems to be solid. The coupler looked fine too. With the rotors still attached, if I pull out on the two rotor gears, there seems to be the slightest amount of play. I can't really feel them move but if I push and pull on them, I can hear a slight tap. Is this normal?
    I'm putting in a new coupler anyway, but don't know if I can leave the car down long enough to wait for the new set of rotors with rotor plate to show up.
    fwiw the fluid was indeed clear in color and there was no metal pieces. If I were desperate enough, and didn't have fluid, there would be no worries reusing the old stuff.
    2010 Camaro SS LS3
  7. #27 Re: too small of a s/c belt???
    Kansas City, MO
    Maybe when things heat up, the housing expands?
    who knows I guess.
  8. #28 Re: too small of a s/c belt???
    St Louis MO
    who knows I guess.
    I mean when it is cold just sitting there w/o the snout on (it's torn apart right now). Would there be any play when grabbing the rotor gears and not turning them, but pulling on them and pushing them back in? ya know jiggling them in and out?
    2010 Camaro SS LS3
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. Total new system,, small space 2005 supercharged
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 10:27 PM
  3. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  4. Turbo Civic Vs. Small block Bronco !
    By Meemperor in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:40 AM
  5. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
