Thread: lights dim when braking
Results 1 to 3 of 3
  1. #1 lights dim when braking
    GT Level Member hourang's Avatar
    commerce, mi
    i noticed when i first press the brake that my lights will dim for a second then go back to normal. do i have a bad ground somewhere? alternator not putting out enough current? short in the abs system (which works fine)?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: lights dim when braking
    Outer Space
    Thats normal IMO. My volts bounce when I hit the brakes or have a turn signal on. However, you have options for increasing voltage.
    Search for ALT Rewire and some vendors sell diodes that increase voltage...ie ALT Volt Booster or a ALT overdrive pulley. I have a alt booster on my car... my volts are around 15.5... but still bounce.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: lights dim when braking
    commerce, mi
    yeah i saw the alt rewire kit, may have to try that. i thought it may be normal but wanted to make sure.
    -Jeff
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. odd braking issue, maybe ABS?
    By Pittman06 in forum General Tech Discussion
    Last Post: 11-05-2009, 02:52 PM
  3. Odd issue... Pop/Clunking sound shifting into 2nd OR braking hard...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-09-2009, 10:28 PM
  4. Anti lock braking system problem?
    By knightriider in forum General Tech Discussion
    Last Post: 03-25-2009, 03:59 PM
  5. braking problem
    By beastin1 in forum Brakes/Suspension/Chassis
    Last Post: 12-11-2008, 09:25 AM
