Thread: Removing/cleaning headlight and side marker lenses
Results 1 to 8 of 8
  1. #1 Removing/cleaning headlight and side marker lenses
    GTX Level Member bronzemist02's Avatar
    Canada
    I went to replace one of my fog light bulbs today and noticed that I had about an inch of water sitting in my drivers side corner lens. I removed the corner lens and drained the water out by removing the push in cap by the signal bulb and put the lens back in place on the body.
    I am wondering if there is an easy way to remove the lenses for the corners and headlights so they can be cleaned and resealed. There is obviously a large leak somewhere in the corner lens and the headlights are fogged up as well.
    See the attached picture for what my drivers side lights look like after I drained the water out of the corner lens. Thanks.
  2. #2 Re: Removing/cleaning headlight and side marker lenses
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    mine is doing the same thing. i took it out, put it next to the heater to dry and im sealing it with clear silicone. try to c if it works. mines not as bad as yours tho.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Removing/cleaning headlight and side marker lenses
    Canada
    Thanks. I took a rag and screwdriver and cleaned out my corner lens as much as I could earlier. Only problem with me taking lights out is I have an appointment to get them aimed tomorrow. :P Passengers corner lense is in great shape, but headlight is pretty dull looking.
  4. #4 Re: Removing/cleaning headlight and side marker lenses
    Dec 2008
    Lawndale, CA
    You can use a hair dryer or heat gun to dry out the moisture. Then reseal them around the edge and where the bulb goes in with silicone. That should help. Sometimes the little gasket that is on the bulb socket gets old and does not make a good seal.
  5. #5 Re: Removing/cleaning headlight and side marker lenses
    Canada
    Okay. Thanks. They are brand new bulbs, so they shouldn't be leaking around the bulb. I took them out today and they seemed to have a good seal.
  6. #6 Re: Removing/cleaning headlight and side marker lenses
    Banned - Busted For Scamming
    Feb 2009
    The problem lies in the sealer gm chose to put the headlights together, its not the normal butyl sealant. It sucks. Take apart the housing and get the correct headlight sealant.
  7. #7 Re: Removing/cleaning headlight and side marker lenses
    Canada
    How would you easily take apart the housing? Without heat gun or something like that I mean.
  8. #8 Re: Removing/cleaning headlight and side marker lenses
    Charles City, IA
    Bake it.
    SMGPFC Two Nipple General
  1. Cleaning headlight covers
    By mikes_comp_g in forum Detailing Tips and Tricks
    Last Post: 12-22-2008, 09:10 AM
  2. cleaning the engine and headlight
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-22-2008, 09:39 PM
  3. Removing P0300 misfire code side effects....
    By Trannyman95 in forum PCM Tuning
    Last Post: 07-11-2008, 12:29 PM
