Thread: sunroof visor stuck open
Results 1 to 15 of 15
  1. #1 sunroof visor stuck open
    GT Level Member hourang's Avatar
    commerce, mi
    my sunroof visor will not close, its stuck. it was open all the way and i tried to close it and was able to move it about 1-2in now its stuck. ive tried putting a lot of force on it and nothing. any ideas?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: sunroof visor stuck open
    SE Level Member Skeeve's Avatar
    carneyville FL
    mine does this, i found that if you close the visor while closing the sunroof from fully open it will slide easily into place.
    99 Grand Prix GT
  3. #3 Re: sunroof visor stuck open
    commerce, mi
    Quote Originally Posted by Skeeve View Post
    hrm ill have to try that. im affraid to try opening my sunroof as its winter and im affraid i wont be able to close it, i havent tried yet. im sure it will be fine tho.
    -Jeff
  4. #4 Re: sunroof visor stuck open
    Banned - Busted For Scamming
    Feb 2009
    What has happened is there is two plastic caps on the end of the slide rail for the visor near the back of the headliner. They are rivoted in one place and if you put too much force into opening it they will snap off. Then the end of the sun visor has a lip on it will catch and you wont be able to get it back up. You can try to push up on the headliner near the back of the car maybe 2/3 the way back while you pull the slide closed and dont push it all the way back next time.
  5. #5 Re: sunroof visor stuck open
    Jun 2010
    South Mississippi
    Thanks so much! Your advice saved me a heck of a lot of time and/or expense.
  6. #6 Re: sunroof visor stuck open
    West Side Michigan
    You could also take off the sunroof glass. It's not that hard. Put the sunroof up and there are I think 6 star headed screws? Three on each side. You will see them on the mechanism that brings the glass up. Unscrew it from the inside of the car. Once you have all 6 off go from the outside, and then carefully just lift the glass out of place. Then you can look down and see those metal/plastic tabs that keep it on track. You can probably see what the problem is after that. I would suggest doing it in a garage though since it is cold/snowing outside. Good Luck!
  7. #7 Re: sunroof visor stuck open
    commerce, mi
    great info guys thanks! yeah i insulated my garage including the door, so it stays decent in there, if its too cold i turn on the 55k btu propane heater, tho it actually gets too hot with that thing on.
    -Jeff
  8. #8 Re: sunroof visor stuck open
    commerce, mi
    hrm i tried messing with it last night. sunroof works great btw. could not get it to close. so i need to try to close it while im closing the sunroof? i dont think i did that. ill see if i can try again, if not i may have to remove the sunroof if its not that hard.
    -Jeff
  9. #9 Re: sunroof visor stuck open
    GTP Level Member SuperSport's Avatar
    Michigan
    I cant stand being in a car with the sunroof visor closed. But thats just me.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  10. #10 Re: sunroof visor stuck open
    commerce, mi
    yeah i hear you, if i get it working ill probably wont use it still. i really just want it for my baby in the back for in the summer. when its just me it will never be closed.
    -Jeff
  11. #11 Re: sunroof visor stuck open
    GT Level Member AmericanRiceEater's Avatar
    New York
    Junk it
  12. #12 Re: sunroof visor stuck open
    Willoughby, Ohio
    ^^^? thats helpful
  13. #13 Re: sunroof visor stuck open
    commerce, mi
    Quote Originally Posted by CTKGP09 View Post
    ^^^? thats helpful
    yeah wtf?
    -Jeff
  14. #14 Re: sunroof visor stuck open
    Donating Users LuckyBambu's Avatar
    Feb 2010
    Chicago, IL
    Apologize for the bump...
    My visor is stuck back, but not back so far that the handle isn't visible. Tried pushing up 2/3 the way back and pulling forward but doesn't seem to work.
    Is removing the headliner and doing it by hand a viable option?
    2000 Pontiac Grand Prix GTP Stock
    Coming Soon: Headers, Intake, Tune, Pulley Drop, Thermostat, Spark Plugs, Ported Supercharger, Ported Throttle Body, Coolant Switch (Green Stuff ), Headlights/Taillights, Speakers, HUD Fix, LED Interior
  15. #15 Re: sunroof visor stuck open
    commerce, mi
    Quote Originally Posted by LuckyBambu View Post
    probably but its a pain to remove the headliner. someone posted that you can remove the sunroof glass with 6 screws and get to it that way. havent tried it yet myself, i never block the sunroof anyway so i havent cared much.
    -Jeff
  1. Sunroof visor question
    By SNeitzel in forum Visual/Body Modifications
    Last Post: 02-27-2010, 01:31 PM
  2. Who steals one vent visor?
    By Durk Diggler in forum The Rant Forum
    Last Post: 08-02-2009, 10:23 AM
  3. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
  4. sunroof wont open
    By whitegtp in forum General Tech Discussion
    Last Post: 03-24-2009, 08:08 PM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
