Thread: quick help with pulley
Results 1 to 14 of 14
  1. #1 quick help with pulley
    toronto
    hey guys, newbie here so bare with me. i am starting to mod, but wont go all out like some of you (can't afford to). i plan on ordering today from 3800performance the following:
    reflashed pcm, 180 thermostat, autolite 605 plugs, 3.4" supercharger pulley and gator belt and a thrasher cold air induction kit. also plan on doing u bend delete. i only drive the car in the summer, and i dont drive the car hard, drive about 120 kms/75miles per day.
    with all that said, can i get away with going down to a 3.4" pulley with those mods safely? i will not do any more exhaust work. i know a guy who just changed his pulley and nothing else and had no problems. obviously i wont go that route so all help is appreciated, thanks.
  2. #2 Re: quick help with pulley
    read link in my sig
    And if you REALLY want to push your luck, run 87 octane as well.
    Just don't be surprised we say "told you so" if you lose your front bank of pistons.
    And thanks for repping our provincial capital so poorly.
  3. #3 Re: quick help with pulley
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    Look at my sig. All that i did to run a 3.4. Others have done even more. Your friends car isnt gonna hold up ad yours wont either.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: quick help with pulley
  5. #5 Re: quick help with pulley
    Wausau, WI
    no, you cant do it safely the way you have it listed above. Read this and it will tell you what you have to do to run a 3.4 and pcm safely:http://www.grandprixforums.net/f81/safely-modding-your-3800-powered-car-17482.html
  6. #6 Re: quick help with pulley
    toronto
    thanks for the input. as for matt5112, no problem, the rest of canada hates toronto anyway so what does it matter, do you expect anything less?
  7. #7 Re: quick help with pulley
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    just because your friends car was "ok" doesn't mean anything. did he scan it? doubt it. pullies are not the 1st mods. with my mods and a 3.5 i knock. so a close to bone stock and a 3.4 will eventually grenade. go ahead and list your car on "parts for sale"....not trying to be an a$$ but read the stickies, their here to help u new people!
  8. #8 Re: quick help with pulley
    Skip the U-Bend...get headers. You should be able to run a 3.4" for the most part...save some money...make your own intake...don't buy a gatorback, its a waste of money...get a reg. belt sized for the 3.4"...I can't stress enough how much you need to read my Safely Modding Your 3800 Thread.
    Your motor also needs 91+ octane...all the time. It keeps knock down.
  9. #9 Re: quick help with pulley
    lmao, a blown car on 87. what is this world coming to?
    Its toronto... its a terrible place... Big city-ish driving which means no fun, stupid people and stupid traffic.
    Also has this: CN Tower - Wikipedia, the free encyclopedia
  10. #10 Re: quick help with pulley
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    damn canadians.
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  11. #11 Re: quick help with pulley
    Donating Users blowfishRus6's Avatar
    g.a.
    exhaust. more than just a u bend delete.....
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: quick help with pulley
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Well, in today's day and age and the "KR" epidemic, you won't be able to get away with these mods and a 3.4 pulley.
    I guess these guys weren't around when we used to put a u-bend delete, intake, 104 plugs and an intake on and go right to a 3.4 .... guess what, a lot of us lived and learned, we are still up and running. 87 octane is a no-no though...
    For all your 3800 needs:
  13. #13 Re: quick help with pulley
    you can run a 3.4 on a stock car, but no one said the car would run better.
  14. #14 Re: quick help with pulley
    Run a 3.1" Injectors still won't run static
  1. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
