Thread: mass air flow sensor compatiblity
Results 1 to 8 of 8
  1. #1 mass air flow sensor compatiblity
    SE Level Member daveydavido's Avatar
    Feb 2010
    detroit
    ive used the search, no results and i wasnt about to search maf and go through all the threads so...
    will a 99 maf sensor from a gtp work on my 97 gtp?
    mine isnt necessarily bad but it has a crack on top plastic, looks someone hit it with a hammer... is it necessary to replace?
  2. #2 Re: mass air flow sensor compatiblity
    Charles City, IA
    No it will not fit. 97-98 used different MAF sensors.
    SMGPFC Two Nipple General
  3. #3 Re: mass air flow sensor compatiblity
    Topeka, KS
    Indeed. PM KFISH he has a few for 50 bux i believe shipped.
  4. #4 Re: mass air flow sensor compatiblity
    it will physically fit, but youll have to retune for it.
  5. #5 Re: mass air flow sensor compatiblity
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It will only fit if you drill a new opening in the throttle body and remove the center post. The 99+ MAF is very, very different.
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: mass air flow sensor compatiblity
    well, im thinking from the perspective of having both MAFs in a 99+ throttle body. ive switched back and forth that way without much problem, but yes, you cant use it the other way around. that was my mistake.
  7. #7 Re: mass air flow sensor compatiblity
    Feb 2010
    detroit
    alright thanks guys, im going to the junkyard after this snow melts, im sure theyll have one, im guessing gtps and n.a grand prixs have different mafs?
  8. #8 Re: mass air flow sensor compatiblity
    QCA, IA
    Quote Originally Posted by daveydavido View Post
    The MAF is the same.
    Edit, scratch that. I know they're the same on the 99+, but I'm not so sure on the 97-98. Sorry.
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. P0102: Mass or Volume Air Flow Circuit Low Input
    By anicolay in forum General Tech Discussion
    Last Post: 04-30-2009, 12:59 PM
  3. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  4. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
