Thread: Window Problem
Results 1 to 6 of 6
  1. #1 Window Problem
    Charlotte, NC
    I have an '04. The other day I tried to roll the window down to get soemthing from my mail box. I hit the switch and hear the motor run but the window didn't move. I then pushed up and heard the motor run again with no movement from the window. This is making me think that it is off track. any advice?
  2. #2 Re: Window Problem
    Donating Users kfish's Avatar
    Ohio
    id say you tried to roll it down while frozen, and you snapped the cable in the regulator
  3. #3 Re: Window Problem
    Charlotte, NC
    Can you point me to a guide on how to remove the door panel? is it an easy fix? I found a new regulator cable. Can I just replace that or do I need to replace the whole regulator?
  4. #4 Re: Window Problem
    Ohio
    youll probably need a new regulator. the door panel should have 2 torx bits under the pull handle and the rest of it is held in with push pins. the 97-03s are like that at least. ive never messed with an 04+
  5. #5 Re: Window Problem
    Charlotte, NC
    Thank you for the info.
  6. #6 Re: Window Problem
    Ohio
    no prob.
  1. Window fog. How to get rid of?
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-10-2013, 12:49 PM
  2. Another window problem...L/F cable issue
    By Pittman06 in forum General Tech Discussion
    Last Post: 10-31-2009, 09:33 AM
  3. pass window problem
    By wxman25 in forum General Tech Discussion
    Last Post: 06-30-2009, 03:49 PM
  4. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  5. Window problem
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 05:09 PM
