Thread: Silverstar headlight dillema
Results 1 to 9 of 9
JoelW98GTP Silverstar headlight dillema 12-27-2009, 08:53 PM
a98gtp4u Re: Silverstar headlight... 12-27-2009, 09:41 PM
matt5112 Re: Silverstar headlight... 12-27-2009, 09:44 PM
The Guz Re: Silverstar headlight... 12-27-2009, 10:07 PM
Warhellride Re: Silverstar headlight... 12-27-2009, 10:16 PM
DaytonaGTP Re: Silverstar headlight... 12-28-2009, 10:06 AM
matt5112 Re: Silverstar headlight... 12-28-2009, 10:33 AM
JoelW98GTP Re: Silverstar headlight... 12-28-2009, 07:36 PM
bronzemist02 Re: Silverstar headlight... 12-28-2009, 07:43 PM
  1. #1 Silverstar headlight dillema
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    I put in new factory replacement headlights and they still aren't bright enough (deer season). I went to the parts store to get some silverstar lamps. They didn't have the regular silverstars in stock but they had the silverstar ultras but they were $42. Are the ultras worth the extra cash or should I take them back and order the regular silverstars? I've never used any silverstars, so input would be appreciated. Thanks!
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  2. #2 Re: Silverstar headlight dillema
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I have the $14 shipped ebay 85ook bulbs in mine and they r just as bright or brighter than the ultras. One way 2 go if u wanna save some money.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Silverstar headlight dillema
    stop being cheap and get projectors.
    Then if thats still not enough light, get HID's.
    97-03 PONTIAC GRAND PRIX BLK PROJ HEADLIGHTS +XENON HID:eBay Motors (item 140369351512 end time Dec-27-09 19:42:14 PST)
    Theres both...
  4. #4 Re: Silverstar headlight dillema
    Dec 2008
    Lawndale, CA
    The ultras are supposed to be alittle better than the regular sivlerstars. They are also not supposed to burn out as quick as the regulars. If you want to sae some cash look into a set of GE nighthawks. They are a better bulb since they do not have any blue tint on the glass bulb.
  5. #5 Re: Silverstar headlight dillema
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    x2 on avoiding blue bulbs. Blue bulbs are going to reduce your output.
    ORIGINAL = Daniel Stern Lighting Consultancy and Supply
    In fact, you get less usable light from such a bulb than from a regular clear bulb, and here's why: A blue filter removes nonblue components of the light passing through it. Halogen bulbs produce very little light in the blue frequency range. When you put a blue filter on the bulb or lamp, you are reducing the amount of usable light that gets from the glowing filament to the reflector, to the lens and from there to the road. If a bulb's sales material focuses on the color of the light rather than the amount of light, you should ask critical questions about the amount of light the bulb produces before choosing to use it.
    Probably the best 9007 bulb you're going to find is the Philips X-treme Power +80. It puts out slightly more light than a regular bulb, and uses a smaller filament (closer to a point source) and more precise arrangement to improve the beam pattern and direct the light down the road.
    If you're really looking for better visibility, though, I'd recommend getting projectors. Even with high efficacy bulbs, you'll still be limited by the 9007 housing. The two filaments in the bulb interfere with the beam pattern, scattering the light and reducing the usable output. Even with halogen bulbs, the projectors direct a lot more usable light down the road than the 9007 housing is capable of.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  6. #6 Re: Silverstar headlight dillema
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    silverstars are crap. in the time it takes you to buy HIDs then replace them you would have replaced the silverstars prolly 3 or 4 times over. so either way its gonna cost you the same. the life of silverstars dont last any longer than regular lights which is why they are much cheaper. i could be wrong though...
  7. #7 Re: Silverstar headlight dillema
    Quote Originally Posted by DaytonaGTP View Post
    Actually less.
    If they burn brighter, they can't last as long.
  8. #8 Re: Silverstar headlight dillema
    Nov 2009
    Portsmouth, OH
    I just installed the ultras. They are pretty bright. Not as good as HIDs though. To those of you about me getting the HIDs, I just installed the new factory replacements thinking that was the problem with lack of vision. Here goes, don't flame me...... I don't like the way the HIDs look on a GP. Just a personal preference. lol
  9. #9 Re: Silverstar headlight dillema
    GTX Level Member bronzemist02's Avatar
    Canada
    I just got some ultras. I asked about the nighthawks and the ones I would consider getting are a fair bit more than what I paid for the ultras.
  1. Need HID Headlight help
    By TooMch in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2009, 11:37 AM
  2. New headlight help
    By betsgtp in forum Visual/Body Modifications
    Last Post: 10-19-2009, 07:47 AM
  3. Headlight
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 03-20-2009, 09:49 PM
  4. Anyone used the Silverstar ultras?
    By archemedes in forum Visual/Body Modifications
    Last Post: 12-20-2008, 01:33 PM
