Thread: Power steering...how to bleed system???
Results 1 to 9 of 9
  1. #1 Power steering...how to bleed system???
    Nov 2009
    Sheridan,Indiana
    I have a 2000 GTP. Does anyone know the proper way to bleed the air from the power steering system. I just replaced a leaking pressure hose in the system. It had to be replaced because my DP was rubbing it and caused it to fail.
  2. #2 Re: Power steering...how to bleed system???
    Charles City, IA
    get the front wheels off the ground. Then disable fuel so it will not start. Crank the engine while turning lock to lock for about 30 sec let it sit do that again. Then drop the front end down and do it with the engine running.
    SMGPFC Two Nipple General
  3. #3 Re: Power steering...how to bleed system???
    GXP Level Member Zef_66's Avatar
    PA
    I always just fill it with fluid and drive it. The air eventually works itself out. Turning lock to lock will help bleed the system. But I never heard anyone recommend doing it while cranking the engine over.
    2001 GSE
  4. #4 Re: Power steering...how to bleed system???
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    x2^^^
  5. #5 Re: Power steering...how to bleed system???
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    ya.. lock to lock 50 times or so withi it off. than same thing with it running. top off and drive
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  6. #6 Re: Power steering...how to bleed system???
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    how does the engine running stop air from getting out?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: Power steering...how to bleed system???
    PA
    Quote Originally Posted by Jakegday View Post
    With the engine running, and the PS pump turning, the oil can cause cavitation, or get air bubbles in it. And therefore won't get all the air out and cause issues. But again, even though this has happened to me, just driving it a little bit has always worked for me.
    2001 GSE
  8. #8 Re: Power steering...how to bleed system???
    Nov 2009
    Sheridan,Indiana
    Outstanding!! Thanks alot guys.
  9. #9 Re: Power steering...how to bleed system???
    Charles City, IA
    You leave the cap of when cranking. It works great.
  1. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
  2. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  3. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  4. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
