Thread: Pully
Results 1 to 18 of 18
40thgtp Pully 03-21-2008, 01:30 AM
nemesis Re: Pully 03-21-2008, 01:46 AM
40thgtp Re: Pully 03-21-2008, 01:47 AM
FoSHO99 Re: Pully 03-21-2008, 02:11 AM
IndeedSS Re: Pully 03-21-2008, 07:34 AM
40thgtp Re: Pully 03-22-2008, 12:50 AM
nemesis Re: Pully 03-22-2008, 04:27 AM
IndeedSS Re: Pully 03-22-2008, 07:35 AM
Reptile Re: Pully 03-22-2008, 08:36 AM
FastKatt Re: Pully 03-22-2008, 08:41 AM
40thgtp Re: Pully 03-22-2008, 01:16 PM
Going Too Phast Re: Pully 03-22-2008, 01:31 PM
40thgtp Re: Pully 03-23-2008, 12:41 AM
FastKatt Re: Pully 03-23-2008, 12:51 AM
IndeedSS Re: Pully 03-23-2008, 08:01 AM
40thgtp Re: Pully 03-23-2008, 04:15 PM
Reptile Re: Pully 03-24-2008, 06:49 PM
FastKatt Re: Pully 03-24-2008, 07:42 PM
  1. #1 Pully
    So, of coarse, another noob question. All I want to know is where to find the cheapest 3.4 pully. I don't have a pully remover or anything, I am not sure what kind to get. I have looked on zzp and i can't figure out which one to get. So any help would be greatly appreciated,thanks.
  2. #2 Re: Pully
    chicago
    which kind you looking at? press on or mps? i go with zzp 3.4 mps and don't forget to buy the hub too
  3. #3 Re: Pully
    See, I have no clue. I don't know what the advantages are, just something easy, i guess is what i am saying. I mean, something that I will not have to take off the supercharger.
  4. #4 Re: Pully
    Jan 1970
    Maquoketa, Iowa
    What are your supporting mods? You can't just slap on a 3.4" pulley, you need intake, exhaust work, plugs, pcm work and a few other small mods to make the 3.4" pulley safe for your car...
  5. #5 Re: Pully
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    You will need access to one of these. ZZ Performance
    And this is the pulley system although judging by your cheapest comment I would go no smaller than a 3.5 or better yet a 3.6 ZZ Performance
    And of course you'll need a 660 one of these ZZ Performance
    And you really shouldn't do any of these things without one of these.
    AeroForce Interceptor Gen II Scan Gauge - GM OBD-II Vehicles [AF1-OBDII] - $259.00$239.00 : MarylandSpeed.com- Your First Stop on the Way to Performance!
    or http://www.hptuners.com/order.php
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Pully
    ok, all I have right now is an intake, dhp pcm, no resonator and u bend delete. Besides that all stock.
  7. #7 Re: Pully
    chicago
    my first mod all i have were 3.4 thrasher pulley, thrasher cai, pcm and 180* tstat. i don't remember running into kr. i run that same mods for 1.5 year. i don't see him having problem running 3.4 pulley with what mods he have. don't get me wrong it would good idea to get a scanner to be safe.
  8. #8 Re: Pully
    St Louis MO
    Most will NOT be able to do a 3.4 and only limited support mods without knock. I was only able to run a 3.4 after headers, 1.9 rockers, 180*, Wizaired. Still had to run rich to pull it off though. I would have been faster with a 3.5 and leaner AFR. However, I've always had a scanner/tuner and have kept an eye on things through all of my different stages.
    2010 Camaro SS LS3
  9. #9 Re: Pully
    Bastard Reptile's Avatar
    Kansas City, MO
    In the long run...ZZP makes the most cost effective and most choice available pulley system. Get the Modular system, it makes pulley changes less than 5 minutes. You could get you a stock size, and then say get a 3.6. I know that the sizes don't sound like they would make a big difference, but you would be very surprised at the difference between a stock and 3.6
  10. #10 Re: Pully
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Quote Originally Posted by Reptile View Post
    x2!
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  11. #11 Re: Pully
    really? ok thanks. So, what is the stock size?
  12. #12 Re: Pully
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by 40thgtp View Post
    3.8
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  13. #13 Re: Pully
    k, so you think just with my supporting mods that I should just go with a 3.6 or 3.5? Is that worth the $200 you think? (puller and modular pully system)
  14. #14 Re: Pully
    Feb 2008
    Rkrd, IL
    Get a used MPS w/Pulley from the "For Sale" areas on our vast amount of forums...
    $40-$60 most likely
    Find someone with a puller, buy him a case of beer, help him hold tools while he swaps your pulley with the MPS Hub...
    Call it a day
    Even if you need to buy a 2nd pulley, used, looking $40 more at max?
    So, $55-$125...
  15. #15 Re: Pully
    St Louis MO
    ^^^ that is the way to go and save money. Spring is rolling around and there may even be a local mod day come up near you. Once you have the MPS hub installed there should never be a reason to remove it.
    2010 Camaro SS LS3
  16. #16 Re: Pully
    cool, i will look through the for sale forum, thanks for helping me out.
  17. #17 Re: Pully
    Kansas City, MO
    Quote Originally Posted by FastKatt View Post
    $40-$60 most likely
    Call it a day
    So, $55-$125...
    A CASE of beer? Good lord, I'm selling myself short! I usually do it for A beer. lol
  18. #18 Re: Pully
    Feb 2008
    Rkrd, IL
    LOL
    Case = 12 bottles...
    And it's shared between the 2 of you while you mess around in the garage
    Cans FTL
    So, $11.49/2=$5.75 and a good buzz
