Just as a heads up, Fullsize IC +3.8 pulley needs a 695 belt, not a 685. It would never fit.
I didn't see i belt for the zzp l36 sc ss kit m90 kit with a scic. Any thought on what belt i shoud use with the short stack and a 3.5/3.6 pulley anf the l36 kit
the ZZP L36 SS top swap kit is not that popular and the short stack isn't very popular either, so it doesn't surprise me that no one has gone through the effort to find out what belt is needed. I would contact ZZP to see what they recommend. you might end up having to use some rope to route over everything and then taking a measurement of that.
I stepped up to a larger s/c tensioner pulley for more belt wrap on the s/c. 38001 Gates pulley on my 04. It is 3 inches diameter and all other specs are the same as the stock 38006. It will kiss the s/c idler pulley until you get the belt on and it gets pulled away. I found going .2 inches down on pulley size and going to the larger tensioner pulley balanced out perfectly for belt size.
Seems like the pulley picture is no longer functional. So I am posting this picture for future needs.Attachment 15706
Click on the picture to enlarge.
any suggestions on belt size when a belt wrap kit is being used with a short stack intercooler and a 2.8 pulley?
