Thread: bad vibration... suspension? motor mounts?
Results 1 to 2 of 2
  1. #1 bad vibration... suspension? motor mounts?
    Jul 2008
    sumter,south carolina
    so i have this vibration, when i go into a sharp curve or hit a dip in the road it vibrates like hell... it only does it under acceleration ... not at a set speed... it sounds/feels like its coming from driver side front area... the harder i accelerate into a curve ( right hand turns only) or hit a dip in the road going straight... the worse the vibration gets... any ideas what it is?
    02 GTP with mods 05 GP for DD
  2. #2 Re: bad vibration... suspension? motor mounts?
    PA
    Vibrations on acceleration are usually a sign of a bad CV shaft. Check for excessive play and consider replacing.
    2001 GSE
  1. top motor mounts
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 12:49 PM
  2. motor mounts
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-01-2009, 01:35 PM
  3. flipping motor mounts
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2009, 10:39 PM
  4. Poly Motor Mounts
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2008, 09:33 PM
  5. New Chrome Motor Mounts
    By stkks in forum Visual/Body Modifications
    Last Post: 09-11-2008, 07:40 AM
