should i port my gen III or just get a gen v? i plan on running e85 and small pulleys...
I'm sorry I have to totally disagree. A gen V blower is an excellent mod choice for someone looking to go fast. The design of the Gen V rivals that of the best ported Gen III. They run cooler, and they are much louder!
Why would a ported blower be last on someone's list? When you port a blower or upgrade one you are bringing in more air, last time I checked out stock heads flow nicely and are in no way maxxed out by the stock Gen III. A Gen V or ported III is an excellent mod choice.
because a blower just doesnt add up as far as a power per dollar mod. if you seriously buy a vendor ported blower then youre not very smart from the get go when its pretty easy to port by hand or get one cheap from one of the members on here.
the fact is that a genV is a waste of money for his level. a genIII will do its work just fine.
Well, I have to stick with my opinion on this one and respectfully disagree with you here. Looks like he has headers, I'm sure a downpipe upgrade also, and an intake. A gen V will open his potential up drastically. They run more efficiently, you can push more boost out of them without getting them as hot. Like I said a Gen V is like a fully ported Gen III.
i will never argue that a genV isnt a better blower. it is by far, but its just not worth the minimal gains he'll see until he gets in the 3.0 pulley range or lower. i would never waste $400+ on a genV unless i was already maxed out in other areas to NEED that blower.
why waste the money porting the gen 3, just use that money for the Gen V. i wish i had.
a Gen V is 20% more efficient than a ported Gen 3
not everyone has the tools or skills or the money to try on spare parts.
all it takes is a little reading and the right bits to use on a $50 dremel. it might take a while, but it will work. the main thing you have to do is to extend the outlet to be open on the big end instead of having those square notches jutting into it.
but none of that needs to be done on a GenV![]()
