Thread: Water Pump Installation Question
Results 1 to 7 of 7
  1. #1 Water Pump Installation Question
    Outer Space
    For those who installed a water pump, did you use a paper or rubber gasket? RTV or No?
    Thanks!!
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Water Pump Installation Question
    Wooster, Ohio
    RTV no matter what, unless you like doing things more then once
  3. #3 Re: Water Pump Installation Question
    Outer Space
    Quote Originally Posted by Pittman06 View Post
    There is a reason why I asked that....
  4. #4 Re: Water Pump Installation Question
    Donating Users blowfishRus6's Avatar
    g.a.
    i think mine was a rubber gaskets and i rtv'ed the piss out of it and the bolts.
    no leaks.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: Water Pump Installation Question
    Outer Space
    Cool, I installed mine after cam swap... and when I cranked it up...it leaked. I used a gm gasket, but no RTV. I plan to RTV it.. however some tell me not to do that..incase RTV gets in the cooling system.
  6. #6 Re: Water Pump Installation Question
    Wooster, Ohio
    dont soak it and throw it on, when exposed to oxygen it won't dry for a long time. And use the better blue rtv in the silver tube. If you put it on (just keep it out of the water passages) and let it set on the pump loose for a few minutes, then slap it on and wait an hour or so after tightening it to adding coolant you'll be fine
  7. #7 Re: Water Pump Installation Question
    g.a.
    i waited a over night. dident have any issuies.
    its slow.
  1. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  2. 3.1 water pump housing?
    By bfx racing in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-20-2009, 10:48 PM
  3. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  4. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  5. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
