Fishpony
I would unplug the negative battery terminal for awhile and see if that resets it first off. If it doesn't go off right away then drive it for a few days and see if it clears itself. You might check online and see if there is a reset procedure for the SRS system but most cars don't have one. The last resort would be to take it to a dealership OR take out your airbag module and send it to myairbags.com and have it cleared. There could possibly be a code in the module itself. i've had modules cleared by these guys and they work fine. That would be my last resort because as long as nothing is messed up with the system it should reset itself and you're going to spend 100 at the dealership or 49 sending your module in.
Hope this helps. Let me know.
