Thread: Intake help!
Results 1 to 12 of 12
  1. #1 Intake help!
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    Okk so i just attempted my intake on my 06 GTP and i ran into a problem. The IAT is not just a clip in anymore but an actual harness that is a complete section of the tube.... how do i connect it into my intake. Right now i just used the old tube with the flexible rubber pipe as well but that makes half of my intake 3" and half 4".
  2. #2 Re: Intake help!
    MO
    i'll get a picture of mine i just did for you... on my 06
    <brandonl2000> LMAO D!!
  3. #3 Re: Intake help!
    MO
  4. #4 Re: Intake help!
    GTX Level Member cerick08GP's Avatar
    Well, hard to say 100%. Imo that thing is the MAF not the IAT, again I‘m not sure of this.
    Regardless, to my knowledge the only CAI that will work (straight up bolt on) with an 06 is the Wizaired series 3 option. People have made all kinds of crazy stuff “work”, I hope someone can give you more help.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Intake help!
    Nov 2009
    Canada
    Thank you for those pictures! So as far as I can tell that wire harness I'm talking about doesn't matter? And like you said ceric, it would be the MAF.
    If that's the case I just plug that little nipple in and the tie the harness off somewhere?
  6. #6 Re: Intake help!
    MO
    no i have it run, just turned it down so it doesnt show. you want your mass air flow. if you want i'll give you a rundown of exactly what i did. there's a couple little tricks you can't see in the pictures
  7. #7 Re: Intake help!
    Nov 2009
    Canada
    Oh alright, I need both pieces then. Ok so how did you do yours?
    Right now like I said earlier I just used that stock black pipe with the MAF and connected it in with my coupling
  8. #8 Re: Intake help!
    MO
    i bought one of the rubber 90* 3" plumbing joints, cut it at a little less than 45*, then bought some of the plastic intake tubes from o'reilly's, cut off about an inch and a half, left the lip, and wedged it into the cut off side of the bend (make sure to sand off allllll shavings) and used that between the intake and MAF. but i'm running the short ram.
  9. #9 Re: Intake help!
    Nov 2009
    Canada
    Ok perfect I'm going to try that tomorrow. Thanks for your help!
  10. #10 Re: Intake help!
    MO
    the reason you need the plastic piece on the inside is because the rubber won't stay mounted in the coupling, it needs something more solid to grip so the plastic tube acts as a reinforcement. good luck
  11. #11 Re: Intake help!
    the biggest bend you want is a 22.5* bend. that is all you need.
  12. #12 Re: Intake help!
    Nov 2009
    Canada
    I put it all together last night, I bought a 3-3 coupling for the throttle body, connected the MAF into the other end, then I put the 3-4 coupling onto that and connected my filter with PVC.
    Its all straight and the tip of the filter touches the fenderwell. It whines like crazy lol
  1. intake....
    By gotboost3 in forum General Tech Discussion
    Last Post: 04-25-2010, 01:41 AM
  2. New Intake
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2009, 01:01 AM
  3. intake
    By samborski06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2009, 03:58 AM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  5. intake...
    Last Post: 04-29-2009, 01:59 PM
