Thread: defogger dont work
Results 1 to 3 of 3
  1. #1 defogger dont work
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    my defogger in the front just gave up on me, anyone a clue what it could be? my reg heater works, just not my defogger
  2. #2 Re: defogger dont work
    Oct 2008
    Calgary, Alberta
    Most likley a vacuume line somehere, under hood, around battery/ in wiring harness or under air box cracked. Or vacuum line under dash pinched.
    Are any of the modes switching? a/c vents and floor heater?
    I will assume you only have temperature control, no mode controll whatsoever.
    My 98 gtp didn't seem to have the vacuume reservoir, but the line by the battery was very fragile with a few cracks. I ended up making a replacement vacuume line out of 1/8" id brake line, routed beside the transmission select cable in the firewall, reducing the length of the vacuume line by at least 1/2. Use the tubing connectors that were on the stock line, and wrap the brake line in the corrugated plastic loom for concealment (this was on the old line, reuse it.)
  3. #3 Re: defogger dont work
    Nov 2009
    stoystown, pa
    hey thanks for the advice, but all it was was the blower motor, go figure)
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. engine light and comp port dont work
    By 1999gpgt in forum General Tech Discussion
    Last Post: 09-29-2009, 06:21 AM
  3. Drive & 3rd Dont engage, 1,2 and Reverse work fine
    By HomeBoyShopnClub in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2009, 12:17 AM
  4. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  5. Trac and ABS dont work!?!?
    By 99gpse in forum General Tech Discussion
    Last Post: 01-01-2009, 01:26 PM
