Thread: 98 grand prix se key stuck in ignition
Results 1 to 7 of 7
  1. #1 98 grand prix se key stuck in ignition
    SE Level Member Squishy's Avatar
    Apr 2009
    Chemical Valley
    Please help, as described in the title, the key is stuck in the ignition and is draining the battery. It wont come out so we have to turn the key all the way back to the aux. position. It has a remote keyless entry so we jsut lock it up at night and leave the key in there. Its been this way for a few months now and i cant stand having to boost it in the morning while my mom goes to work and hearing she needed to get boosted at work to get home. PLEASE HELP!!! what is wrong?
    Thanks in advance
    Nate
    00 chrysler intrepid se
    98 pontiac grand prix se
  2. #2 Re: 98 grand prix se key stuck in ignition
    Charles City, IA
    The first problem is you didn't use the search button. You would have found your answer. It is probably the park lock solenoid. It is a white solenoid in the column by the ignition switch. Take it out throw it away then your key will come out when ever you want it to.
    SMGPFC Two Nipple General
  3. #3 Re: 98 grand prix se key stuck in ignition
    Joliet, IL
    x2! throw that shyt out! but for now there is a hole on the bottom of the steering column you can stock something in to manually release your key...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: 98 grand prix se key stuck in ignition
    Apr 2009
    Chemical Valley
    so that will stop the dingging adn the battery dying?
  5. #5 Re: 98 grand prix se key stuck in ignition
    Joliet, IL
    Quote Originally Posted by Squishy View Post
    the dinging is your car letting you know the key is in the ignition so yes
    00 Silvermist GTP
  6. #6 Re: 98 grand prix se key stuck in ignition
    Nov 2009
    ILLINOIS
    When I worked at a Pontiac dealer we saw this problem all the time. The solenoid built into the shifter was bad. You had to replace the shifter to get the key release solenoid working properly again.
  7. #7 Re: 98 grand prix se key stuck in ignition
    Nov 2009
    davie
    take down the plastic peice at the bottom of the steering wheel where the key is. You are going to see a plunger like thingy near the key. push it inward and turn the key to the off position and move the key. my car did this all the time. just tie a string around the plunger peice to make it stay inward and put everything back and the key should come out all the time
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. 2008 grand prix key stuck in ignition
    By goldcoinkid in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 05:11 PM
  3. key stuck in ignition?
    By jaketrey32 in forum General Tech Discussion
    Last Post: 05-15-2009, 05:28 PM
  4. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
  5. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
