Thread: fuel injectors
Results 1 to 7 of 7
  1. #1 fuel injectors
    SE Level Member jp2001gtp's Avatar
    hookstown PA
    ok what fuel injectors shoed i look into geting?
    corrent MODS have zzp 3 inch down pipe with highflow cat and custome catback system.
    zzp 33# GM injectors
    ZZ Performance
    ACCEL 150136 - ACCEL Fuel Injectors 36lbs
    ACCEL 150136 - ACCEL Fuel Injectors - Overview - SummitRacing.com
    Trick Flow Specialties TFS-89036-1 - Trick Flow® TFX™ Fuel Injectors 36lbs
    http://www.summitracing.com/parts/TFS-89036-1/
    42.5# Lucas Injectors
    ZZ Performance
  2. #2 Re: fuel injectors
    Charles City, IA
    none you dont need them unless you want to run around a 3.0 pulley
    SMGPFC Two Nipple General
  3. #3 Re: fuel injectors
    Someone tried to tell me my car would benefit from bigger injectors... And my car is a stock GT.
  4. #4 Re: fuel injectors
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    If its not boosted then stay with stock inj, look in the 4sale section u might find some or just get them new?
  5. #5 Re: fuel injectors
    hookstown PA
    the zzp 33# GM injectors
    ZZ Performance
    are the way to go?? their remaned stock inj.
  6. #6 Re: fuel injectors
    No? Unless yours don't work, don't buy any.
  7. #7 Re: fuel injectors
    Jan 1970
    Maquoketa, Iowa
  1. 97 GTP fuel injectors
    By DSkyles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 11:22 PM
  2. Fuel Injectors Leaking?
    By skidsteer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2009, 10:46 AM
