Thread: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
Results 1 to 20 of 30
  1. #1 Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    SE Level Member Purple Plazma's Avatar
    Nov 2009
    Trevose,PA. (near Philly)
    I just this weekend realized my '98 GTP coupe is not worth putting on the road due to excessive rot. My question is, if I find a nice GT doner car, say with a bad engine or trans, is it possible to transfer my GTP "goodies" into the GT easy enough to wind up with a true GTP? Yeah, I know, "easy" is a relative term. In other words, would any items need to be fabricated, welded on ( i.e. tabs or brackets), etc ?
  2. #2 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Apr 2009
    Wausau, Wisconsin
    Nothing custom. Look in the general forum there is a lot of good info there.
  3. #3 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Peace of cake haha. I've made a write-up for both the motor swap as well as the HD swap. Transmission isn't really needed to swap and is also an easy 3.29 gear upgrade, unless of course this is the reason you pick up the donor GT for cheap, in which case just swap motor and trans and run the GTP PCM. Simple plug and play
    http://www.grandprixforums.net/f73/l...deo-23248.html
    http://www.grandprixforums.net/f73/h...ans-22464.html
    also, if not already installed on the car here's a good HUD/DIC install guide
    http://www.grandprixforums.net/f73/a...03-a-8171.html
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  4. #4 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    GT Level Member 02gtpsleeper's Avatar
    Hanover Park, Illinois
    what about top swapping the l37 motor? would that make any more or less power? my gtp has 90k on it and i was thinking about lookin for a gt with low miles and just swapping all my mods and such over, but i didnt think it'd be that easy
  5. #5 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Norristown, PA
    l37?
  6. #6 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    top swapping an L36*** is the same as doing the head gaskets cept you just put on the L67 top half instead of L36
  7. #7 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Nov 2008
    The reliability of a topswap to me doesn't make it worth it. I'd rather just stick the whole motor in and have it last
  8. #8 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Jersey
    Quote Originally Posted by ninnyGTP View Post
    what makes it unreliable? I beat the **** out of my car, motor is
    16' wrx sti- stock
  9. #9 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    If theres no knock, theres no real issue.
  10. #10 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    yea.. sorry l36, but i hear different pistons and such on the n/a motor. so would putting supercharger on that motor still come with 240 hp? or would it be greater or less?
  11. #11 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    higher compression so 252 is what you'd get "in a perfect world"
  12. #12 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    May 2008
    staten island,NY
    i have a GTnowP...no big deal
  13. #13 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Jersey
    even L67 guys are swapping to L36/26 blocks...
    16' wrx sti- stock
  14. #14 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    i would never use another l67/l32 block again on an m90 build. turbo build only.
  15. #15 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Overall the swap is easy.
    Pull the motor/trans together, put them into the new car together and add/change a couple wires then program the pcm for the correct year/engine trans combo.
  16. #16 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Guam
    Quote Originally Posted by Purple Plazma View Post
    Just curious, how bad is it? Unsafe to drive?
  17. #17 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Nov 2009
    Quote Originally Posted by toolguy View Post
    Check out just a few of the pix I posted in the Lounge in the thread "97-"03 owners a must see"
    How about everything underneath from the "B" pillar back is badly rusted or completely rotted through.This includes areas of the rocker panels, ALL brake lines , parking brake cable, suspension parts, etc. So, NO BRAKES AT ALL and gaping rotted holes.
  18. #18 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Oct 2008
    Northern Illinois
    Topswap setups are just as reliable as a GTP if you do it right. But it has more power than a gtp.
  19. #19 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Quote Originally Posted by BwolfGT View Post
    Are you running the stock pulley?
  20. #20 Re: Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    Oct 2008
    Northern Illinois
    Yep. And after some of fastkatt's tuning I've got zero knock most of the time. SOMETIMES I see .5*. 3.8 pulley. Some say to do 4.0, but from what I've seen that's not necessary at all.
  1. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  2. do they make these?
    By riceburner in forum Visual/Body Modifications
    Last Post: 12-01-2008, 10:13 AM
  3. trying to make some more power from a 04 gt 2
    By Martin 04 in forum Introductions/Noob Questions
    Last Post: 11-03-2008, 07:27 PM
  4. This Will Make Your Day
    Last Post: 07-28-2008, 04:29 PM
  5. Any way to make 6 1/2 speakers fit?
    By Deezul_AwT in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2008, 11:03 PM
