Thread: 04 turn signal?
Results 1 to 9 of 9
  1. #1 04 turn signal?
    Nov 2009
    canada
    the front turn signal bulb in my 04 grand prix burnt out. how to i get to it to replace it? it seems like it would be hard to do it from the top or the bottom? do i take the lens off?
    Thanks
  2. #2 Re: 04 turn signal?
    Guam
    Doesn't your owners manual explain how to do it?
  3. #3 Re: 04 turn signal?
    Nov 2009
    Michigan
    what if it dident come with one when he bought it like mine
  4. #4 Re: 04 turn signal?
    Guam
    Quote Originally Posted by Tofast4u2011 View Post
    It was just a suggestion so the person could get the answer and steps quicker and on their own, that is all...
    Here is a download for a 2004
    http://www.extendedgmwarranty.com/ow...-GrandPrix.pdf
    Page 5-62 has it, you need to remove the headlamp first, then you can get to the park/turn bulb.
  5. #5 Re: 04 turn signal?
    Nov 2009
    Michigan
    thxs
  6. #6 Re: 04 turn signal?
    GT Level Member gpgt04's Avatar
    MA
    the turn signal is in the fog light. its just two phillips head screws.
  7. #7 Re: 04 turn signal?
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    Quote Originally Posted by gpgt04 View Post
    X2, just pull the foglight. Much easier to change when not installed. Not sure if anyone else had this problem but when mine when out it was actually a bad harness. Just fyi if changing the bulb doesn't solve ur problem.
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  8. #8 Re: 04 turn signal?
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    Quote Originally Posted by PonchoDvr4Lfe View Post
    not only did i have bad harness but figured out that autozone also doesnt even carry the correct 3 use bulb... just a 2... replacing a turn sugnal every 3 weeks got old real quick
  9. #9 Re: 04 turn signal?
    canada
    the manual in my 2007 says to remove the headlight and go in from the top, if i rmember correctly. for other reasons I removed my turn signals with a philips head screw driver, two screws each, and I though, with the exception that they are low to the ground, would it not be easier to change the bulb this way than going in from the top?? anyway just remove them and change bulb and put back, that simple
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  3. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
  4. Turn signal Issues
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 10:39 AM
  5. Turn Signal on Solid
    By coolken84 in forum General Tech Discussion
    Last Post: 08-31-2008, 01:39 AM
