Thread: does this look right? muffler installation
Results 1 to 20 of 27
rocafella2032 does this look right? muffler... 11-21-2009, 01:18 PM
97gtsc Re: does this look right?... 11-21-2009, 01:22 PM
BwolfGT Re: does this look right?... 11-21-2009, 01:24 PM
TheOtherNick Re: does this look right?... 11-21-2009, 01:26 PM
rocafella2032 Re: does this look right?... 11-21-2009, 01:35 PM
TheOtherNick Re: does this look right?... 11-21-2009, 02:08 PM
Liquifire Re: does this look right?... 11-21-2009, 02:15 PM
superv6 Re: does this look right?... 11-21-2009, 02:17 PM
rocafella2032 Re: does this look right?... 11-21-2009, 02:53 PM
rocafella2032 Re: does this look right?... 11-21-2009, 03:00 PM
blueguy Re: does this look right?... 11-21-2009, 03:41 PM
BwolfGT Re: does this look right?... 11-21-2009, 03:55 PM
02gtpsleeper Re: does this look right?... 11-22-2009, 02:46 PM
blueguy Re: does this look right?... 11-23-2009, 12:35 AM
rocafella2032 Re: does this look right?... 11-21-2009, 04:02 PM
Bio248 Re: does this look right?... 11-21-2009, 04:51 PM
TorqueAutoMotiv Re: does this look right?... 11-21-2009, 05:33 PM
silverstreak Re: does this look right?... 11-21-2009, 06:02 PM
99prixgt Re: does this look right?... 11-21-2009, 05:48 PM
rocafella2032 Re: does this look right?... 11-21-2009, 06:44 PM
Liquifire Re: does this look right?... 11-22-2009, 09:32 AM
Pittman06 Re: does this look right?... 11-21-2009, 08:11 PM
rocafella2032 Re: does this look right?... 11-22-2009, 02:32 PM
rocafella2032 Re: does this look right?... 11-22-2009, 02:50 PM
Pittman06 Re: does this look right?... 11-22-2009, 08:29 PM
nawarkk Re: does this look right?... 11-23-2009, 12:43 AM
TheOtherNick Re: does this look right?... 11-23-2009, 06:51 PM
  1. #1 does this look right? muffler installation
    Norristown, PA
    i got my borla mufflers put on by monro, the exhaust tips stick out pretty decent amount. There not centered with the cut outs and the right one is rubbing against the bumper.
  2. #2 Re: does this look right? muffler installation
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    That looks f***ed up, go back and tell them to fix it!
  3. #3 Re: does this look right? muffler installation
    Oct 2008
    Northern Illinois
    No that doesn't look right at all, and they're crooked as ****.
  4. #4 Re: does this look right? muffler installation
    Charles City, IA
    Yeah have them give you money to get it fixed and take it some where else.
    SMGPFC Two Nipple General
  5. #5 Re: does this look right? muffler installation
    Norristown, PA
    what do i say to them?
  6. #6 Re: does this look right? muffler installation
    Charles City, IA
    If the tip is really hitting your bumber they did worse than a half ass job. Tell them that. If you told them you wanted the tips flush with the body they should have done that too.
  7. #7 Re: does this look right? muffler installation
    Wausau, WI
    tell them that the quality of work is unacceptable. They need to either re do it the right way or give you your money back. That does not look good at all. Dont go in all pissed off, just try to explain it professionally and see what they are willing to do to make it right. Explain to them what you want it to look like. Tell them that it should be centered, not rubbing on anything and if you want them flush mounted with the rear bumper area or how far you want them sticking out. Stay calm and see what they are willing to do to make the situation right. This way you both know what you expect and what the finished product should look like.
  8. #8 Re: does this look right? muffler installation
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    That sucks. U shouldn't have even left the shop bro. Yeah get that fixed
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  9. #9 Re: does this look right? muffler installation
    Norristown, PA
    i just got back from there, he fixed it a little, the one not rubbing but they are still sitting low and out. Due to me having work today at 430 i need to set up a day where he can have more time to re do it. hopefully he gets it right this time
  10. #10 Re: does this look right? muffler installation
    Norristown, PA
    FAIL
  11. #11 Re: does this look right? muffler installation
    FAIL for having a hole in the wall crap shop like Mieneke, Monroe, or Midus weld your mufflers and tips on. Should have taken it to an exhaust shop.
  12. #12 Re: does this look right? muffler installation
    Oct 2008
    Northern Illinois
    Yup
  13. #13 Re: does this look right? muffler installation
    GT Level Member 02gtpsleeper's Avatar
    Hanover Park, Illinois
    Disagree. its all about the technician. You could have an idiot working for BMW and the smartest **** in the world working at some shop. Dont blame the company, blame the **** tech.
  14. #14 Re: does this look right? muffler installation
    Quote Originally Posted by 02gtpsleeper View Post
    Sorry...but about 99.9% of the time who are you going to find working at a place like that vs. a place like BMW. Most of the BMW techs are college educated in that field vs. the quacks that work there dropped out of high school after auto shop class.
  15. #15 Re: does this look right? muffler installation
    Norristown, PA
    Thanks. To bad there aren't any around here so I had no other option.
  16. #16 Re: does this look right? muffler installation
    the tips look like they are out of the bumper the right amount, but it looks like they missed a hanger or welded it in the wrong spot. you might be able to fix it a little bit with a hose clamp around the muffler hanger itself.
  17. #17 Re: does this look right? muffler installation
    Apr 2009
    stockton ca
    people just dont take pride in the jobs they do any more
    My exhaust guy took almost 20 minutes getting my side pipes on my other car lined up right Id definatly have them get it lined up right
  18. #18 Re: does this look right? muffler installation
    in a house
    Quote Originally Posted by wickedintent79 View Post
    X2. The place I went the guy took the same amount of time. And when he thought it looked right, he came and got me for my approval before he welded anything. Any quality place will do that. Personally, I wouldn't have left with it looking like that
  19. #19 Re: does this look right? muffler installation
    Jersey
    LOL! wtf, i would have, ripped the muffler off the car and slapped the guy in the face with it.
    16' wrx sti- stock
  20. #20 Re: does this look right? muffler installation
    Norristown, PA
    It's not done you guys. They are going to fix it. The tips will however still stick out some but that's obvious since it's a longer muffler. The alignment of it will be fixed
  1. Muffler
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2009, 03:29 PM
  2. Muffler
    By zewski2469 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 11:21 PM
  3. Glasspack Muffler
    By 04GrandPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 09:41 PM
  4. Muffler swap
    By bladerunner in forum 5.3L V8 (LS4)
    Last Post: 02-11-2009, 07:19 PM
  5. help with muffler set up
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2008, 07:50 PM
