I've got about 80k on mine.
How far have you guys gotten with yours?
I know someone with one on his mustang and he has around 100,000 but hes replacing it with a new unit figures better safe then sorry
they say they are good for 2500+ hours so who knows
So, I was having issues with my cooling system. On a cold start, it would act like the thermostat would not open. The temp would go up to 240ish and I would shut the car off. I wouldn't have heat at this point either. Eventually the temp would drop down, I would get heat, and it would be fine. It would not over heat after that but the temperature would fluxuate 15-20*. The whole time I could hear the pump running and I bleeded the crap out of the system.
I changed the rad cap, thermo, ran a pressure test on the system, combustion gas die test, checked flow in all directions to find a blockage and hooked the pump up to 12v not mounted to make sure it spun.
Finally I just swapped the stock WP back on and problem solved. I noticed a much better flow looking in the rad cap and I had heat much sooner.
Just a FYI cause I've never seen any info on one failing.
Meziere said they would rebuild it for $150 too.
I was wondering the longitivity of these units. I've been wanting to get one of these for sometime now, but I'm wondering if I should just get a mechanical when the time comes.
BTW, my original Mechanical pump on my White GTP has 170,000+ on it. My Black GTP has 150,000 on its original as well....
If youre looking to gain a miniscule amount of hp for the money and problems then get one. Otherwise, get some different mods.
I would get one for the track. Running it with the car off cooling down.
I have one because the price was right. So far, zero issues. Although I'm pretty sure I don't have the same mileage on it like you do Mike.
And I never noticed one ounce of additional power.
