Thread: Part time headlights, all the time
Results 1 to 6 of 6
  1. #1 Part time headlights, all the time
    Feb 2010
    West Carrollton OH
    I just have a question about my headlights. Why are they on all the time? I checked to see if anything was maybe blocking the light from the sensor but it looks ok. Would a bad sensor cause that? in all three switch positions the headlights and taillights stay on even in full daylight. My lights flicker when i turn the switch but that's it. My dash lights also. I haven't started troubleshooting yet because truthfully i have no idea where to start. Anyone have any idea?
  2. #2 Re: Part time headlights, all the time
    GTP Level Member SuperSport's Avatar
    Michigan
    They are called Daytime Running Lights, and unless youre in Canada, you don't need them. Pop off the little door on the drivers side dash when the drivers door is open, and you will see a heatsink in there with a blue plug. Unplug that and your daytime running lights will go out. All the automatic lights and your headlight switch will work as normal.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Part time headlights, all the time
    Willoughby, Ohio
    if its the headlights that are on and not the DRLs (taillights and dash lights on with headlights when switch is on OFF position) then it could be the sensor. i would get more opinions though...
  4. #4 Re: Part time headlights, all the time
    West Side Michigan
    The lights flicker between the second and third switch. If you can get the switch to stay between 2nd and 3rd then the headlights will go out. BUT if you want to disable the Daytime Running Lights, do what SuperSport suggested.
    Check out this thread if you wanna some pictures:
    http://www.grandprixforums.net/f71/d...ion-24880.html
  5. #5 Re: Part time headlights, all the time
    West Side Michigan
    oops double post :/
  6. #6 Re: Part time headlights, all the time
    Feb 2010
    West Carrollton OH
    Sweet I'll try taking that out thanks for the help!
  1. Cam time
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2009, 12:42 PM
  2. all this time ...
    Last Post: 08-15-2009, 12:33 AM
  3. 0-60 Time
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:42 AM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. Two Time'n
    By ajay in forum Introductions/Noob Questions
    Last Post: 02-09-2008, 06:56 PM
