Thread: hmm....debating....
Results 1 to 20 of 23
  1. #1 hmm....debating....
    Joliet, IL
    i have 2 setups in mind.....
    NIC*GEN V*E85
    FSIC*1.95 RR*93 OCT
    what would you go with?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: hmm....debating....
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    why not like XP, Gen V?
    or Full Size IC, Gen V?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  3. #3 Re: hmm....debating....
    Joliet, IL
    Quote Originally Posted by bbptech View Post
    because if i dont plan on intercooling the NIC cam makes a more power and allows small pulleys....
    if i go intercooled id prob go rockered with a ported gen3 and FSIC
    00 Silvermist GTP
  4. #4 Re: hmm....debating....
    those are completely different setups. like....WAY different. you cannot compare them in any fashion.
  5. #5 Re: hmm....debating....
    research honestly...I don't think you understand what you've got going on there.
  6. #6 Re: hmm....debating....
    Charles City, IA
    Buy a tuner first and learn how to use it.
    SMGPFC Two Nipple General
  7. #7 Re: hmm....debating....
    Joliet, IL
    i thought the NIC cam was meant for those who dont wanna go intercooled?
    so i was saying shoudl i go big cam with a better blower or gen 3 rocker'd and IC'd? what am i missing>?
    00 Silvermist GTP
  8. #8 Re: hmm....debating....
    Quote Originally Posted by BoostJunki3 View Post
    you dont realize those setups are vastly different in how they will perform and how they will run. a NIC setup will NOT be good as a daily driver and unless you know how to tune and have a wideband then youre going to be ****ed. cam or not, an intercooler is a good idea. the only reason a NIC can run such small pullies without an intercooler is because of the stupid amount of overlap that it has. you HAVE TO run small pullies in order to keep boost levels up. its not necessarily a good choice for a cam in any situation.
    therefore we are back at this situation: do you want to run a cam or not? how fast do you REALLY want to go?
  9. #9 Re: hmm....debating....
    Joliet, IL
    ok thanks for clearing that up for me....considering that this is a DD car that i want to be a 12 sec DD then i will just go rocker'd and IC'd....the more i think about it thats prob the best setup for me...thanks bio
    00 Silvermist GTP
  10. #10 Re: hmm....debating....
    Wausau, WI
    12 flat or 12.99?
  11. #11 Re: hmm....debating....
    Joliet, IL
    Quote Originally Posted by Liquifire View Post
    12 flat or 12.99?
    id like to see mid 12 on slicks....i figure if vogel is shooting into the 11's on that setup its possible
    00 Silvermist GTP
  12. #12 Re: hmm....debating....
    Banned - Busted For Scamming
    Feb 2009
    what intercooler you goin with?
  13. #13 Re: hmm....debating....
    vogel had a stupid amount of custom parts and weight reduction. you have to take what he did with a grain of salt. he only ran 12.11.
  14. #14 Re: hmm....debating....
    Joliet, IL
    its in my sig unless your new core is super successful...
    00 Silvermist GTP
  15. #15 Re: hmm....debating....
    Feb 2009
    Do what you want. I was just asking.
  16. #16 Re: hmm....debating....
    Joliet, IL
    ok mr grouchy
    00 Silvermist GTP
  17. #17 Re: hmm....debating....
    Feb 2009
    Well i will be running one here real soon just have to finish it up. I think its gonna be just fine. You can go with what you want, you know the pricing.
  18. #18 Re: hmm....debating....
    And for those that don't?
    In other words, do you have a website?
  19. #19 Re: hmm....debating....
    Logan. Put it on your car and make it work. Enough with the selling it and "seeing" if it works or not.
    As for the OP.
    Just get a S1X or XP and a S2IC from ZZP along with #42.5's and get it tuned.
  20. #20 Re: hmm....debating....
    Donating Users blowfishRus6's Avatar
    g.a.
    As for the OP.
    i agree in alot of ways with this whole statement.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Debating which way to go
    By Dropped GP GT in forum General Tech Discussion
    Last Post: 09-20-2009, 11:13 PM
  2. tire size debating...
    By gotboost3 in forum Tires & Wheels
    Last Post: 05-06-2009, 12:29 AM
  3. Debating on what to do...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 06:31 AM
